Fuel Injector Clinic 1GR-FE groupbuy (FEELER)
Discussion in 'Automotive Group Buys' started by loginfailed, Jun 24, 2019.
  1. Jun 24, 2019 at 7:04 PM
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    I’m in for a set of 445’s. Talked to them today and they have them.
    loginfailed[OP], 1slow4.0 and JustDSM like this.
  2. Jun 24, 2019 at 7:06 PM
    DiamondW
    Kent
    Gonzales Co. TX
    And thanks @loginfailed i was gonna reach out to you about this soon, you beat me to it.
  3. Jun 24, 2019 at 11:32 PM
    loginfailed
    loginfailed [OP] Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Added! :thumbsup:
    Mine idles a bit smoother and I believe @Roostfactor said his idles smoother too. He and I were running Siemens Deka 640cc injectors before (from URD). I don’t have a frame of reference on idle smoothness of the stock injectors because I haven’t run stock ones for a couple years.
    The difference with flow matched injectors vs. not flow matched isn’t likely something you will notice on the butt dyno. It is a more precise match so that each cylinder gets the same amount of fuel. When you’re firing away at 5-6000 RPM you want them to be as close as possible for safety and smooth power delivery.
    Normally aspirated 1GR = 330 cc/min
    Supercharged TRD 1GR = 455 cc/min
    It won’t hurt to go larger than you need. 650cc is the biggest most of us (99%) will ever need. There are some outliers (the other 1%) such as @Torspd who is I believe currently running 1300 cc/min injectors.
  4. Jun 24, 2019 at 11:33 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Added! :thumbsup:
    DiamondW[QUOTED] likes this.
  5. Jun 25, 2019 at 4:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    True statements on both points. Mine are 1300 ccm. Only if turbos, large rotrex, or larger liter twin screw blowers are installed will a larger set be needed.
    More pounds per minute of air equates to more HP potential, which in turn means more fuel requirements.
    P.S. which likely also means rods,pistons, and head studs. ;)
  6. Jun 25, 2019 at 8:04 AM
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    @loginfailed So just so I understand this right - These FIC injectors coupled with the billet fuel rail are not so much power gainers but more of a safety net from lean out conditions ?
  7. Jun 25, 2019 at 8:05 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Yes exactly
    loginfailed[OP] likes this.
  8. Jun 25, 2019 at 8:12 AM
    garciav
    Houston, TX
    TRD SC,HPTuners
    So what size should I get ? currently I'm just running the s/c on the stock pulley, but piecing parts together swap to the 2.8", as well as 3 deg cam gears
  9. Jun 25, 2019 at 8:43 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    650s hands down. Or bigger
  10. Jun 25, 2019 at 9:01 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    650 cc/min will support up to 600 at the crank.
    I have the FIC 650 cc/min injectors with stock air cleaner, AFe ProDry drop in filter, supercharger w/2.5 pulley, headers, JFR y-pipe, 1141 resonator and TRD exhaust. My injector duty cycle last I looked was about 65% at WOT 5500 RPM. When I had stock injectors on a similar setup, the duty cycle was 95% (very scary, lol)
    Hawk373, garciav[QUOTED] and oni06 like this.
  11. Jun 25, 2019 at 9:08 AM
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
    Yes!!! Im in!.... Put me down for the 650’s. Thanks for putting this together sir :hattip:
  12. Jun 25, 2019 at 9:09 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Got it! :thumbsup:
    Braunschwaga[QUOTED] likes this.
  13. Jun 25, 2019 at 9:46 AM
    garciav
    Houston, TX
    TRD SC,HPTuners
    Put me down for the 650's then..
    so what happens when the injectors hit 100% duty ? full lean out ? Ka-boom ?
    DiamondW likes this.
  14. Jun 25, 2019 at 12:46 PM
    garciav
    Houston, TX
    TRD SC,HPTuners
    So what happens if I just run these injectors and no billet fuel rail ? what is the advantage of adding the billet fuel rail ?
  15. Jun 25, 2019 at 3:53 PM
    #35
    DiamondW
    Kent
    Gonzales Co. TX
    Bling, and a bigger well to draw from so more consistent rail pressure.
  16. Jun 25, 2019 at 4:01 PM
    #36
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    There is no problem using the stock rails. That’s what I’m currently running.
    This right here ^^
  17. Jun 25, 2019 at 5:28 PM
    #37
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    I’m in for 650s
  18. Jun 25, 2019 at 5:29 PM
    #38
    DiamondW
    Kent
    Gonzales Co. TX
    There’s got to be more than 4 of us that missed out on the first round. We need to make this happen!
  19. Jun 25, 2019 at 5:58 PM
    #39
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’ll add you to the list! :thumbsup:
    Spread the word! :D
  20. Jun 25, 2019 at 6:00 PM
    #40
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    5 more!
