Fuel injector questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by carrollcustoms, Mar 27, 2013.
  1. Mar 28, 2013 at 1:26 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    It looks to me as if the OP is getting close and there is some good advice so far, maybe a compression check and a check of the suspect injector grounds? Is this an auto or man trans?
    Just for the record, there is no vacuum modulation of the FPR on most of the V6 engines (non SC) despite what the FSM says. The ones that have it were early production T 100s and possibly some early Tacos. They also had an EGR system, 99.9% sure on this last point. The intent was to increase fuel pressure on a hot restart to hasten said restart. The ECM was involved controlling a VSV that in turn would modulate manifold vacuum to the FPR. This deal was soon dropped and the little rubber hose on most Taco and 4R FPRs is just a clean air vent for the atmospheric side of the FPR diaphragm. Fuel pressure is fixed at around 43 PSI. It might also provide a degree of safety should the diaphragm leak.
  2. Apr 9, 2013 at 10:50 AM
    taco65
    taco65 Member
    steve
    canada
    Magnetic grey and pyrite. yes two of them god help me.
    Unmodded and staying that way.
    I have read on here more than a few times about guys changing out there iac valve. they made no big deal about it, so I was wondering what you fellas in the states pay for yours. I was going to replace mine but the dealer told me it was 600 plus. holy crap. there is a very large price difference from American to Canadian Toyota oem parts I know, but that little thing is expensive up here.
