Fuel injector service.... is it necessary
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rhowell, Feb 3, 2013.
  1. Jan 5, 2022 at 2:11 PM
    tacomatrddave
    tacomatrddave Well-Known Member
    2023 Tacoma Access cab sr5 v6 4wd
    Sumo springs. Shocker air hitch.
    I have my own garage and lift. Do all my own service. Only thing dealer does is oil changes. They are free for life of vehicle. So that’s why I go. Saves me over $100 a year. 6 qts synthetic and filter are just expensive enough to make ot worth it.
    I decided dump in a bottle of tectron. Just for good measure. Truck runs like day I drove it out of showroom and it’s got 142,000 miles since new in 2016. So I figure leave it be. Nowhere in any service book is that service mentioned. And in 35 years of high mileage vehicles I’ve never done injector cleaning. My vehicles work their butts off. I life to drive and travel. Only major service was the timing cover sealant at 132,000 and Toyota nicely paid for that.
    so it’s all good.
  2. Jan 5, 2022 at 2:23 PM
    TacoTuesday1
    SD CA
    So how exactly does a fuel cleaner help your direct injectors,
    when that video is referring to port injectors and their multiple little spray holes
    and how exactly does a cleaner remove carbon buildup on your unwashed valves,
    when you inject it into the cylinder...
    Chevron gas comes with Techron already in it
    It sounds like occasionally you give the truck a workout through load, RPM, and long trips, which is good for it, as opposed to people who don't.
    It is good you are the original owner who has the 0 miles perspective to compare it to.
    Most 2nd gen owners for example did not buy new, so they have no idea how the truck felt at 0 miles. I know I don't, having bought it with 130k on the clock.
    Jimmyh likes this.
  3. Jan 5, 2022 at 2:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    All that shit is just snake oil
    If you have concerns about "dirty" injectors (I'm talking port injected here), pull them out and get them cleaned
    If you have concerns about carbon buildup on intake valves (fairly common on DI motors) the only repair worth a shit is to pull the intake manifold and media blast (acorn shells) the valves at each port
    Jimmyh, Holling and Biscuits like this.
  4. Jan 5, 2022 at 2:41 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Drive more worry less.
    Holling and tacomatrddave like this.
  5. Jan 5, 2022 at 6:03 PM
    tacomatrddave
    Fortunately I’ve always bought them knew. Run them to 300k and amazingly still sell for a decent price. On my gen 2 and gen 3 I’ve always found rpm’s are my friend when towing my camper. Usually hold it in 4th. That keeps beginning in the 2k to 3 k range. On the gen 3 on hills it is not unusual for the engine to rev to 4k plus on a bill when it drops to 3rd. But that gen. 3 engine smooth as silk in higher rpm’s.
    I never baby them. I don’t abuse them either. But I like to work them.
  6. Jan 5, 2022 at 6:52 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I'm going to drive up to your shop for all my maintenance needs.
    b_r_o[QUOTED] likes this.
  7. Jan 5, 2022 at 6:57 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds good, don't forget to grab beer. After 5pm we can shut the doors and BBQ out back
    After 28 hrs on the highway your intake valves will be spotless anyways
    fresyota and Biscuits[QUOTED] like this.
  8. Jan 5, 2022 at 6:58 PM
    Holling
    Holling Well-Known Member
    West Coast
    2021 DC TRD Sport
  9. Jan 5, 2022 at 7:00 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    At my dealer a fuel system service included the following and cost $200, it took about 1.5 hours depending on throttle body location and fuel rail connection location/ease of disconnect.
    Throttle body cleaning.
    Fuel injector flush, turn off fuel pump, disconnect fuel rail hose, connect tank of cleaner that uses shop air to pressurize and run engine with cleaner through rails and injectors.
    Vacuum cleaner flush, disconnect an evap hose on intake manifold and attach hose for cleaner that is sucked through the intake and intake valves, in theory gets rid of carbon buildup on valves.
    Fuel tank additive gets added cause why not.
    Reset KAM due to cleaned throttle body.
    I dont think it needs to be done more often then around every 50K at the max, at least good to do when replacing spark plugs around 100K.
