Fuel injector/throttle body cleaner products
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SELAroadrunner, May 15, 2020.
  1. May 15, 2020 at 6:30 AM
    SELAroadrunner
    SELAroadrunner [OP] Well-Known Member
    Ron
    WSNC
    17 Sport
    wheel decals
    Upon a oil/filter change they recommended to have the injectors and throttle body cleaned and serviced. Any recommended products I can use to remedy filth? TIA
  2. May 15, 2020 at 6:46 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Port injection is doing the bulk of the cleaning.
    Places recommend this because they get your money...
    Garyji, pinochle, Vlady and 6 others like this.
  3. May 15, 2020 at 6:49 AM
    SELAroadrunner
    Ron
    WSNC
    17 Sport
    wheel decals
    Only 45k on clock....gumout?
  4. May 15, 2020 at 6:51 AM
    JoeCOVA
    Joe
    Colorado Springs
    To be honest you don’t need it. Today’s fuel has detergents in it, you have decent fuel filter and the engine has port injection to burn away carbon build up.
    What symptoms are you experiencing that makes you think you need to clean the injectors? Or are you doing it because someone tried to sell you something?
  5. May 15, 2020 at 6:52 AM
    wolf2600
    wolf2600 Well-Known Member
    San Jose, CA
    2021 TRD-OR 6MT-SOLD
    Coyoza Tuned
    Not necessary, just something the oil change place "recommends" in order to get you to spend more money with them.
  6. May 15, 2020 at 7:04 AM
    SELAroadrunner
    Ron
    WSNC
    17 Sport
    wheel decals
    I’m with you on notion it’s an attempt to drum up business for sure. Just inquiring about a legit cheap work around.
    as a matter of fact performance hasn’t been affected as far as I can tell.
    I’d be surprised if there was substantial build up but if there’s an inkling I’d like to nip it at the bud if you know what I mean.
  7. May 15, 2020 at 8:15 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    Throw some techron in your tank and your good or any other suitable injector cleaner.
  8. May 15, 2020 at 8:26 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Using name brand gasoline as it has Techron is all you need bro save your money and don’t fall for that line of shit. Tell them I said so.
  9. May 15, 2020 at 8:58 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    My buddies that are dealer techs refer to them as wallet flushes.
  10. May 15, 2020 at 9:05 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    You're gonna get a better return from using quality gas. As stated before port injection (that ticking you hear at idle is cleaning as well) are gonna take care of it. If you're actually needing this done and are on the verge of a tear down, something alot more costly than a bottle of bullshit is required.
    SELAroadrunner[OP] likes this.
  11. May 15, 2020 at 9:29 AM
    SELAroadrunner
    Ron
    WSNC
    17 Sport
    wheel decals
    Thanks folks for confirming my suspicion. Typically run shell 87. Thanks y’all for the solid.
    Junkhead likes this.
  12. May 15, 2020 at 9:51 AM
    SELAroadrunner
    Ron
    WSNC
    17 Sport
    wheel decals
    On another note those of you take your truck in to dealership for oil changes, what brand synthetic are they using. This particular dealer uses pennzoil...just curious
  13. May 15, 2020 at 9:54 AM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    I'm sure any quality synthetic will work fine. If you were in a colder area you could slightly change it up as per the owners manual (or even if you don't have 0-20 it has a sub reccomendation in the manual)
    Edit: I personally just used Mobil 1 synthetic because I got a case of it for 15 bucks on sale. I just did amsoil in my front and rear diff because I got it for the same price as other competitors, as well as have been using it for almost 18 years in many other vehicles including a 2001 dodge 2500 that hauled 10,000 pound fully enclosed snowmobiles up mountain passes every weekend
  14. May 15, 2020 at 10:22 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    For the throttle body i’d remove the tube from the air filter and just spray liberally in and around the throttle valve with any aerosol can of ‘Throttle Body Cleaner’ from the auto parts store. For the injectors, i’ve always just thrown a can of ‘Seafoam’ in the gas tank once a year or so.....
  15. May 15, 2020 at 10:37 AM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    I like using some cleaner and wiping the throttle body bore and throttle plate down. Other than that I throw some Seafoam in the tank once in a while just because. The Seafoam probably doesn't do anything but it makes me feel better lol.
  16. May 15, 2020 at 11:03 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Wipe the throttle body with residue free solvent. Toyota specifically warns against hosing it down.
    They also warn, if learning value reset and idle learning aren't performed after cleaning the throttle body, idle speed might increase.
  17. May 15, 2020 at 11:10 AM
    slowtacotruck
    17 offroad
    stuff
    I've always used BG throttle body cleaner. Just a little will get it done.
    pinochle and SELAroadrunner[OP] like this.
