Fuel injectors
Discussion in '1st Gen. Tacomas (1995-2004)' started by Whitetoyota 2014, Mar 2, 2020.
  1. Mar 2, 2020 at 1:02 PM
    Whitetoyota 2014
    Whitetoyota 2014 [OP] Member
    2014 Tacoma DCSB Sport white 4x4
  2. Mar 2, 2020 at 1:04 PM
    Whitetoyota 2014
    Said a injector circuit malfunctions code P0200 , check engine light
  3. Mar 2, 2020 at 2:30 PM
    Whitetoyota 2014
    Any ideals on that ?
  4. Mar 2, 2020 at 6:45 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Just for curiosity, can you Ohm test the injectors and repost the reading? The reading should be between 12-16 Ohms.
    It is possible for an old coil to fail that would cause an Ohm reading to be too high like 21 or too low like 8. In which case the coil is bad and no cleaning in the world can correct it.
    Here's a video on testing top feed injector.
    https://youtu.be/yFv5IWdANGs
    Kwe1982 likes this.
