Fuel injectors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyotagang, Apr 28, 2022.
  1. Apr 28, 2022 at 12:42 AM
    Toyotagang
    Toyotagang [OP] Well-Known Member
    Kainoa
    2005 black Toyota Tacoma 4cyl 4x4
    Hey had a question im replacing my fuel injector seals and installing on another engine, I got cups and prints for the cup. I got the little tiny o rings for injectors head, do I need the cushion seal and pintel cap as well?
  2. Apr 28, 2022 at 7:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you are going to do it right you should replace all of the soft parts.
    TnShooter likes this.
  3. Apr 29, 2022 at 2:32 AM
    Toyotagang
    Kainoa
    Question can I run without Pintle caps? Is there a problem with that? Thanks!
  4. Apr 30, 2022 at 5:50 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I wouldn't do it. They are there for a reason. They protect the Pintle Tip on older injectors and act as an O-ring retainer for more modern injectors.
    It could cause you to have damaged injectors and fuel leaks.
