Fuel issue 2.7l i4
Discussion in '1st Gen. Tacomas (1995-2004)' started by Adriz21, Sep 30, 2023.
  1. Sep 30, 2023 at 1:21 PM
    Adriz21
    Adriz21 [OP] Member
    1998 toyota tacoma 4x4
    Hi so I have a very weird problem with my truck right now. I have a multiple misfire check engine code and for some reason my truck does not turn on for a about 5-10 minutes after turning it off. For example when I turn my truck off to go into the store and once I come out and try to start it'll crank but it won't start but once I wait about 5 minutes it's start right up. Also when I get gas every single time it'll crank but won't start unless I wait 5 minutes. Can someone please help me.
  2. Sep 30, 2023 at 2:23 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Man sorry
    I’m by no means a ‘guru’ here
    But
    It’s the dreaded ‘hot no start condition’
    Gonna have to search
    FF change seemed to help mine
    Ton of other lil easy fixes
    But from what I have read…..
    80% of permanent fixes are new FP or Injectors
  3. Sep 30, 2023 at 2:26 PM
    Bishop84
    Bishop84 Well-Known Member
    It sounds like a purge valve, its on the passenger side of the engine bay and its a long vacuum hose that leads to the intake.
    I would try to pinch or remove the hose to the intake while filling and see if pressure is passing through the valve (it shouldnt be) while filling.
  4. Sep 30, 2023 at 6:59 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    I had that years ago. Fuel pump. Raise the bed to do it
  5. Oct 1, 2023 at 10:58 AM
    Adriz21
    Adriz21 [OP] Member
    Did you have a check engine light for misfire too? Or do you think that problem is seperate.
  6. Oct 1, 2023 at 3:42 PM
    ControlCar
    Steven
    Sugar Land TX
    From what I read
    No code fires for the hot no start condition
  7. Oct 1, 2023 at 4:33 PM
    Potomus Pete
    Hippy
    No cades like he said
  8. Oct 1, 2023 at 4:35 PM
    Potomus Pete
    Hippy
    When I would come out of the store I would have to hold the key down forever for it to start. Fuel Pump
  9. Oct 1, 2023 at 7:07 PM
    ControlCar
    Steven
    Sugar Land TX
    Not that this fixes the issue
    But
    One thread i ‘rabbit holed’ read said to stomp the gas pedal during 1st try to start. Then start normally
    I dunno
  10. Oct 1, 2023 at 10:30 PM
    Glamisman
    Glamisman Well-Known Member
    Next time she is difficult to start get a spray can of starting fluid, take a large hose off the intake and squirt maybe 2 seconds of fluid into the intake and try to start her, if she fires up immediately it is a lack of fuel that is causing the no start. I forget, does a 98 have coil on plug coils or a distributor?
    ControlCar and Potomus Pete like this.
  11. Oct 2, 2023 at 3:26 PM
    ControlCar
    Steven
    Sugar Land TX
    I like this test^^^
    Glamisman
    If starts after spraying, points to FP?
    Correct?
    Any similar test for the ‘leaking injectors’ causing ‘hot no start’?
    Thanks
    2.4L distributor on MY96
  12. Oct 2, 2023 at 5:48 PM
    Glamisman
    Maybe… it shows a lack of fuel, verify with fuel pressure/volume test then check fuel pressure regulator and if those pass the tests pull the injectors and have them checked. There is no magic bullet to diagnosis… compression, air, spark, fuel.
  13. Oct 2, 2023 at 7:04 PM
    ControlCar
    Steven
    Sugar Land TX
    A firm ^^^
    my FPR passed bench test
    I thought I was a badass and installed FP gauge
    Only to find out(after a member gave me PDF for reference)
    Gauge reading return pressure (fail on my part)
    Thanks G.
  14. Oct 4, 2023 at 4:11 AM
    F.I.LetsGoFishing
    F.I.LetsGoFishing Well-Known Member
    95.5 4wd 3rz mt
    Neglected Original
    A quick test would be to get a noid light in before it cools down to see if the injectors are receiving signal when hot. Not sure about your engine but on the 2.7 you can get to #1 pretty quickly.
    If the noid light is firing then I would check spark.
    Recently discovered that things like connectors can get flakey and interfere with signals to and from the computer from sensors.
    $500+ in parts and 3 months to find out I needed to reseat a connector.
