Fuel issues I think?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Charlestonskiff, Sep 8, 2020.
  1. Sep 8, 2020 at 5:54 AM
    Charlestonskiff
    Charlestonskiff [OP] Member
    Bobby
    Summerville, SC
    2017 Tacoma SR5
    None yet
    So recently, (not all the time) when I go to accelerate, I heard sputtering. Kinda like in the old days when you had cheep gas. Can I use a gas additive or something along those lines?
  2. Sep 8, 2020 at 5:56 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Spark plugs ? Dirty injectors ? Dirty maf sensors or as you said bad gas
  3. Sep 8, 2020 at 6:05 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Also switch to a Top Tier gas...preferably ethanol free.
    xxTacocaTxx likes this.
  4. Sep 8, 2020 at 6:06 AM
    Charlestonskiff
    Bobby
    Summerville, SC
    2017 Tacoma SR5
    None yet
    I did that today, not ethanol free, to see if it helps.
    DAS Taco[QUOTED] likes this.
  5. Sep 8, 2020 at 6:34 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    jmneill likes this.
  6. Sep 8, 2020 at 6:36 AM
    Charlestonskiff
    Bobby
    Summerville, SC
    2017 Tacoma SR5
    None yet
  7. Sep 8, 2020 at 6:40 AM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    Weren’t the 2017’s affected in the LP fuel pump recall?
  8. Sep 8, 2020 at 6:44 AM
    Charlestonskiff
    Bobby
    Summerville, SC
    2017 Tacoma SR5
    None yet
    How do you check for that?
  9. Sep 8, 2020 at 6:47 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No, 2019.
    G8R_Taco[QUOTED] likes this.
  10. Sep 8, 2020 at 6:53 AM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    :thumbsup:
    I’ve seen 18-19 iirc. How about the high pressure fuel pump? I don’t think that was a recall though.
    shakerhood[QUOTED] likes this.
  11. Sep 8, 2020 at 6:54 AM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
  12. Sep 8, 2020 at 6:55 AM
    shakerhood
    Southern Ohio
    Maybe 2018 is mixed in there too. I think there was a TSB for the HPFP if it chirps like crickets.
  13. Sep 8, 2020 at 6:58 AM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    That sounds right. I wasn’t sure if there were issues with the spill valve or just the chirping. Spitballin’...:cool:
  14. Sep 8, 2020 at 7:13 AM
    DAS Taco
    DAS
    2017 TRD Offroad
    For the few extra cents I decided long ago to use nothing but top tier gas in everything...including outboards, lawnmower, generators and ofcourse vehicles...in Alberta where i live Shell premium is ethanol free...in most places.
  15. Sep 8, 2020 at 8:31 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Sounds like what my buddies 2019 tacoma v6 auto does....it you drive a stretch far enough to enter 6th gear then round a very slow corner, huis transmission sometimes will stay in 6th gear really lugging down the engine making the truck stutter, and feel as if you ran out of gas.
    shakerhood likes this.
  16. Sep 8, 2020 at 8:37 AM
    Charlestonskiff
    Bobby
    Summerville, SC
    2017 Tacoma SR5
    None yet
    That happens with mine and now it sputters at times. I have taken it to the dealership and they said they cant find anything wrong
  17. Sep 8, 2020 at 10:29 AM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    Here's what I would do.........
    Use an OBDII code reader to see if there are any error codes or pending codes. If your Check Engine Light was not on, the dealership usually does not perform a diagnostic check. Even if there are no stored codes, use the erase all codes option. This should reset the engine computer. The truck's computer will begin "relearning" your driving habits. If no OBDII reader is available, disconnect the battery cable for about 15 minutes.
    Pour a bottle of Red Line SI-1 fuel cleaner in the gas tank. This is a very good product.
    https://www.redlineoil.com/si-1-complete-fuel-system-cleaner
    Clean the Mass Airflow sensor (MAF). The MAF is near the output area of your air filter box. There are wires going to the MAF. The MAF assembly is held in by two screws. Handle with care! Use a MAF spray cleaner. They do get dirty and can cause problems like you described.
    https://www.crcindustries.com/products/mass-air-flow-sensor-cleaner-11-wt-oz-05110.html
    bulalo and Charlestonskiff[OP] like this.
  18. Sep 8, 2020 at 11:04 AM
    Charlestonskiff
    Bobby
    Summerville, SC
    2017 Tacoma SR5
    None yet
    Thank you I will do this today. thank you
  19. Sep 27, 2020 at 8:42 PM
    SD Quicksand
    Alex
    San Diego, CA.
    @Charlestonskiff
    OP......
    Any update? Have things improved with your truck?
