Fuel leak from back of engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RedWings44, Jun 5, 2023.
  1. Jun 8, 2023 at 6:42 AM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    OP, tell them you want to be there when they start it up. Yes, you’ll have to leave it there over night, but this gives you the best offense. You can be there in that moment it occurs, and they can’t tell you that they can’t replicate it.
    And remember, you’re not married to that dealership. It is hard to find a gem dealership/stout techs, but their out there.
    RedWings44[OP] likes this.
  2. Jun 10, 2023 at 10:04 AM
    RedWings44
    RedWings44 [OP] Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Yeah, I've had a few things denied before that were considered wear items even though there was no way they should have worn that quickly (trim pieces). But I came out ahead here and that was refreshing. All they had to do was make a few clicks on the computer and Toyota said they'd cover it. Even better considering I didn't even buy the warranty through that dealership.
    Yeah, although it still shouldn't be happening. Best as I can tell, the leaking part is some sort of plastic fitting that wouldn't have a clamp or anything either. Hard to see for certain though with where it's at.
    shakerhood likes this.
  3. Jun 14, 2023 at 2:09 PM
    RedWings44
    Michigan
    Appointment is Friday. Near as I can tell, it is coming from one of the two black plastic fittings on the back side of the block. No idea what they are. I also found a bracket that is missing a bolt (likely unrelated) and I have the bolt I believe goes to it. But I also can't reach that so hopefully that'll be addressed too.
  4. Jun 14, 2023 at 6:16 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Good luck, hopefully they get it fixed right this time!
  5. Jun 16, 2023 at 7:17 AM
    RedWings44
    Michigan
    Dropped it off today and showed them a video of what I could see happening. This time they let me speak with the actual tech that is working on it. He thinks he knows what's wrong with it and believes it is possibly a cracked or loose hard line (high pressure line, possibly as suggested earlier in the thread). However, he can't replicate the issue at the moment because the truck is too warm so he is going to wait until the truck cools off (maybe Monday) and try to confirm his suspicion. In the meantime I have a loaner and everything is still covered, by the sounds of it. They also said they would try and further diagnose the belt sound.
    I also failed to mention earlier that I had found a bolt dropped out from a bracket and stuck between the car and engine bay. He confirmed that the bracket holds the wiring harness and wasn't super important, but they would try to get it fixed as well.
    MannyS likes this.
  6. Jun 16, 2023 at 7:34 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Get that leak repaired before you have another problem
  7. Jun 16, 2023 at 11:28 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Texas BBQ!
    ToyoTaco25 and MannyS[QUOTED] like this.
  8. Jun 16, 2023 at 11:43 AM
    MannyS
    Republic of Texas
    With that much flame you will need to grill or cook Santa Maria style. Too much flame for brisket.
    grogie and vivid02 like this.
  9. Jun 16, 2023 at 11:47 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    @Bishop84 doesn't the high pressure fuel line have a ball shaped connection at the pump with a big 17 or 19 mm nut to tighten it down? I've seen those get left loose all the time
  10. Jun 16, 2023 at 1:12 PM
    Bishop84
    Bishop84 Well-Known Member
    that’s what I was thinking, hope it’s addressed properly
    shakerhood and RedWings44[OP] like this.
  11. Jun 17, 2023 at 7:26 AM
    RedWings44
    Michigan
    I checked all connections close to the high pressure fuel pump and could not visually see any fuel coming from them. I actually couldn't see the issue from the top side of the engine at all. What I could see from the bottom, I wasn't even sure if that was the correct area it was coming from, but it was simply the highest point where I could see the fuel.
    I'd love to attach the video, but this site doesn't allow MP4 attachments.
  12. Jun 21, 2023 at 9:03 AM
    RedWings44
    Michigan
    Update: spoke with the dealership today. The official explanation for the fuel leak was that an O-ring went bad in the injector system and it was not related to the previous repairs. They replaced all of the o-rings under warranty as a precaution. I suppose this would explain why the leak sealed up after a few seconds. As if the fuel caused the O-ring to swell up again.
    As for the squeal noise: they still can't get the truck to do it long enough for them to be able to tell what it is but they do hear it.
    As of this post, the dealership still has the truck while they're waiting on payment from the warranty company. I believe they're going to make another attempt at replicating the squeal noise.
  13. Jun 21, 2023 at 10:01 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    sounds like they have not pinpointed the source of the leak and are covering their ass
  14. Jun 21, 2023 at 10:28 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Ask them if they checked the hardline fitting at the high pressure pump
  15. Jun 21, 2023 at 10:56 AM
    #35
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Waiting for payment ? If its covered under your warranty get the keys and ska-doodle. Cant hold that Taco hostage .
    VB25 and RedWings44[OP] like this.
  16. Jun 21, 2023 at 12:27 PM
    #36
    RedWings44
    Michigan
    I believe he initially thought that was the issue when we spoke as I dropped it off. However, when I had watched those lines when recreating the issue, there was no leakage. Additionally I attempted to see if any of the fittings were loose and didn't find any that were.
    b_r_o[QUOTED] likes this.
  17. Jun 21, 2023 at 12:29 PM
    #37
    RedWings44
    Michigan
    I'm not too worried about it. It gives them a chance to try and replicate my other issue again and, in the meantime, they're also covering the RAV4 rental I have that has just over 1k miles. I'm not complaining about 33 MPG at 80 MPH when my Taco MAY get 24 at 70 MPH on a good day.
    AM6217[QUOTED] likes this.
  18. Jun 21, 2023 at 12:30 PM
    #38
    RedWings44
    Michigan
    I'll know soon enough. But how do you figure? An O-ring seemed like a perfectly logical explanation given where I saw the leak coming from (or the area anyway).
  19. Jun 21, 2023 at 12:37 PM
    #39
    RedWings44
    Michigan
    Finally got around to getting the video uploaded so I could share it here. I didn't keep the camera on it very long as I didn't want to be in the path of the fuel and there was really no good angle to view it. This was taken from the driver's side underneath the truck on a cold start. You can see the exhaust and O2 sensor in the foreground for reference.
    joeR6 likes this.
  20. Jun 21, 2023 at 4:58 PM
    #40
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Meh stock, did him a favor.
