Fuel leak from fuel pump
Discussion in '1st Gen. Tacomas (1995-2004)' started by BarnBoy, Mar 6, 2018.
  1. Mar 8, 2018 at 2:27 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    NO SMOKING
    Yellow arrow below shows area of trauma. Had to slide the outer protective sleeve back to see it. Slow seepage.
  2. Mar 8, 2018 at 8:06 PM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    @BarnBoy hope this helps. Looks like that is a short piece of hose for the money too.
    23091E - TUBE SUB-ASSY, FUEL PUMP
    part # 23091-75020
  3. Mar 8, 2018 at 8:49 PM
    BarnBoy
    BarnBoy [OP] Well-Known Member
    96 Tacoma 2wd
    Thats great, thanks for all the help. :)
  4. Mar 8, 2018 at 8:53 PM
    BarnBoy
    96 Tacoma 2wd
    Lol, I dont smoke but yeah, wouldnt want someone throwing a butt under the truck and catching it on fire. That would not be good. At least its only a smallish leak, doesent drip onto the ground and only leaks till the pressure is gone.
  5. Mar 10, 2018 at 10:54 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I didn't realize that. It's good to know. (Been using teflon tape for air and water fittings around the house for years.)
  6. Mar 10, 2018 at 6:31 PM
    BarnBoy
    96 Tacoma 2wd
    To me it looks like its actually coming out of the flair area. BUT, definitely possible that its coming from the joint there skeezix. Gonna have to take a good hard look at it. Thanks
  7. Mar 26, 2018 at 5:54 PM
    BarnBoy
    96 Tacoma 2wd
    Hey guys,
    Update on the leak in case anyone is interested. Finally got back into town and had a chance to work on it. Turns out there was a bunch of varnished gas and crud on the sealing surface of the flair. Cleaned it up so it was spotless and shiny, tightened er up and voila, no leaks! And I was able to use crows feet and not have to drop the tank so double bonus.
    Thanks for the help
