Fuel Leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Broseidon GOTB, Apr 30, 2021.
  1. Apr 30, 2021 at 7:53 AM
    Broseidon GOTB
    Broseidon GOTB [OP] First Photo from the Lot
    Cody
    Nunavut
    2018 Grey Tacoma TRD Sport 6spd
    Hey all,
    I have a 2018 Toyota Tacoma V6. Yesterday I started to smell fuel, but wasn’t sure if it was my truck or the snowmobiles by my house. This morning I gave the wife a ride to work and smelled fuel again follow by a large puddle under my truck. I was able to drive it to a heated garage to work on and while doing so I could see the fuel gauge slowly go down, not drastically, but enough to see. Once I parked a decent amount of fuel came out. I took apart the intake system to look at the fuel rail and such, but it looks dry. Can somebody point me to where else to look to save me some time. Right now the engine too wet and the ground from the melting snow so I’ll have to wait until it drys a bit to start looking for anything noticeable out of place.
    This forum group was awesome with my recent northern Tacoma woes. Hoping I get success again.
    Thanks!
  2. Apr 30, 2021 at 7:57 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Engine area for sure? Folks stealing fuel will cut the filler neck to siphon out fuel.
    The other issue that has been noted was folks nicking the filler neck when enlarging the left drain hole in the bed for a tonneau drain installation.
    RustyGreen and tcjacado like this.
  3. Apr 30, 2021 at 8:01 AM
    Broseidon GOTB
    Cody
    Nunavut
    Y
    Yeah for sure coming from somewhere under the engine bay. Only when running. Forgot to note that I didn’t have any loss in performance.
  4. Apr 30, 2021 at 8:06 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The rodent idea is coming to mind? Maybe one chewed through the flex line between the frame and engine.
    Big tall dave likes this.
  5. Apr 30, 2021 at 9:52 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Any mods?
    Chew likes this.
  6. Apr 30, 2021 at 9:58 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Did you have the fuel pump recall done recently where tech may have pulled or stressed lines or disconnected something to confirm pressure problems near the engine? I'd let if all flash off and vent then look at it. Get it as far away as possible from sparks and open flames.
    Skydvrr and Broseidon GOTB[OP] like this.
  7. Apr 30, 2021 at 9:58 AM
    Broseidon GOTB
    Cody
    Nunavut
    Maybe, I didn’t think they’d be out yet as we are still in winter haha. It’s all tundra so we have arctic fox, hare and siksik.
    tonered[QUOTED] likes this.
  8. Apr 30, 2021 at 9:58 AM
    Broseidon GOTB
    Cody
    Nunavut
    Zero
    hiPSI[QUOTED] likes this.
  9. Apr 30, 2021 at 9:59 AM
    Broseidon GOTB
    Cody
    Nunavut
    No I didn’t get the recall done yet. Yeah I removed the battery and letting it dry.
  10. Apr 30, 2021 at 10:02 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    I would look around the High pressure pump. Pressurized the fuel system by putting the key in acc or atleast unil you hear the fuel pump prime.
    make sure you have an extinguisher handy
  11. Apr 30, 2021 at 10:09 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The HPFP is cam driven. The engine would have to be running. Not a good situation, like you noted.
    I had a fuel leak from the pump flange on my bike. It was running down right onto the header. I made the pucker call to ride it home about 5mi. The clench was real and tight that whole short trip.
  12. Apr 30, 2021 at 10:55 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i would be getting it towed to the dealer..
    Chew likes this.
  13. Apr 30, 2021 at 11:02 AM
    Broseidon GOTB
    Cody
    Nunavut
    I’m in a fly in only spot. No dealer or proper mechanics. I am on my own. Last time I had an issue the only certified mechanic in the hamlet chargers beyond $300 a hour. The bill was crazy and Toyota wouldn’t cover any of it. I am still in fights with Toyota to cover warranty work at another certified mechanic, but they aren’t budging. Seems that Ford is the only company in my hamlet that will honour warranty work up to the cost of what the job would cost them.
    Kev250R and kahanabob like this.
  14. Apr 30, 2021 at 3:19 PM
    Broseidon GOTB
    Cody
    Nunavut
    I went out to where my truck was parked in the snow and it looks like it leaked from the driver side of the engine bay.
  15. Apr 30, 2021 at 3:21 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Dealer under 60k let em have at it
    Edit: shit you're far north might not be an option at the moment
  16. Apr 30, 2021 at 3:29 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Check where the catalytic converter comes out of the engine bay from underneath. There's some fuel lines on the driver's side that come through there I believe.
    Heat cooked em maybe?
    tonered likes this.
  17. Apr 30, 2021 at 7:52 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    this is one for the books, be interesting to find out where it is leaking from.
    just a thought, where is that canister gizmo located, maybe from it?
    Dirk Diggler likes this.
  18. Apr 30, 2021 at 7:57 PM
    Bishop84
    Bishop84 Well-Known Member
    Canister is forward from the spare tire, not likely to leak fuel.
    The fuel neck is likely the cause, pull back the inner liner and use a flash light to look under where the fuel neck goes down.
    If you want to drive 3000kms to me in Calgary I can help you out!
    Skydvrr likes this.
  19. Apr 30, 2021 at 7:58 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Get the recall, they'll probably fix it then for free. you should still be under factory warranty
  20. Apr 30, 2021 at 8:02 PM
    tcjacado
    tcjacado Well-Known Member
    Considering where the op lives, I don't think that's a viable option unless they plan to sled dog tow it there.:anonymous: dude lives north of Canada :fistbump:Screenshot_20210430-200107_Maps.jpg
    Bleep100, kahanabob and Kev250R like this.
