Fuel leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Smcsherry, Jul 9, 2023.
  1. Jul 12, 2023 at 11:03 AM
    #81
    Smcsherry
    Smcsherry [OP] Well-Known Member
    Stephanie
    San Diego, CA, US
    2018 tacoma sr5
    Yeah he basically did. And left it up till the pictures I posted. He lost one of those seals for an injector so I had to go to toyota the next day and get it. And said that I should be able to put it all back together, which I did. But then I found that leak. Which mind you we had to remove to get to the harness. So when he put that back on he clearly didn't do it correctly.
    HondaGM likes this.
  2. Jul 12, 2023 at 11:04 AM
    #82
    Smcsherry
    Stephanie
    San Diego, CA, US
    2018 tacoma sr5
    Thanks, it is what it is though. Trying to show my girls just cause we're "girls" doesn't mean we can't do things or at least try.
  3. Jul 12, 2023 at 11:05 AM
    #83
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Thats what im Wondering...whats wrong with them guys in the San Diego area?Young Beautiful girl needs some help.
    If i wasnt so far i would be there in a Minute.. I would put it completely back together,go fill it up with gas...and take her to Dinner
    Chew[QUOTED] and Smcsherry[OP] like this.
  4. Jul 12, 2023 at 11:06 AM
    #84
    Smcsherry
    Stephanie
    San Diego, CA, US
    2018 tacoma sr5
    I'm in san diego. We'll near like poway. Cause san diego is so big.
    HondaGM likes this.
  5. Jul 12, 2023 at 11:12 AM
    #85
    Smcsherry
    Stephanie
    San Diego, CA, US
    2018 tacoma sr5
    I hope no one thinks I'm looking for something for free or attention. I'd seriously give some.cash and cook some lunch
  6. Jul 12, 2023 at 11:16 AM
    #86
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Remove the sensor on the side for better access to the other nut. When reinstalling it, make sure you use sealing thread tape of some kind so it doesn't leak (ie Teflon tape). You should be able to remove that sensor with a crescent wrench no problem. Just make sure the wrench is on there good and locked in as tight as possible before attempting to remove it.
    When your dude was working on it with you he probably bent the pipe which is why it won't go on easily now. It may be difficult to put it back on even if you do manage to make it loose. You may need to use some coercive power to get it back on there to the point where it threads easily now.
    That pipe is a fuel rail cross over line and can see somewhere in the neighborhood as much as 2100 psi since the 3rd gen uses a high pressure fuel system. You'll know when it's tight on there as it will be more difficult to turn the wrench.
    HondaGM likes this.
  7. Jul 12, 2023 at 11:22 AM
    #87
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Oh no..we dont think that...So is this the only vehicle you have?
  8. Jul 12, 2023 at 11:52 AM
    #88
    Smcsherry
    Stephanie
    San Diego, CA, US
    2018 tacoma sr5
    yeah it is. i do use mothers car when i need to. my uncle called and said i should just find a mobile mechanic.
    HondaGM[QUOTED] likes this.
  9. Jul 12, 2023 at 12:15 PM
    #89
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    There is a Toyota of Poway...they have mobile guys?
  10. Jul 12, 2023 at 12:32 PM
    #90
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Did you try local enthusiasts FB pages? there are some that able and eager to help fellow hobbyist out for not much more than pizza n beer.
  11. Jul 12, 2023 at 12:39 PM
    #91
    Smcsherry
    Stephanie
    San Diego, CA, US
    2018 tacoma sr5
    They don't unfortunately, and if they did they would probably charge a lot.
  12. Jul 12, 2023 at 12:48 PM
    #92
    Smcsherry
    Stephanie
    San Diego, CA, US
    2018 tacoma sr5
    No I don't where to even loom or group to follow
    HondaGM likes this.
  13. Jul 12, 2023 at 2:12 PM
    #93
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    :sorry:.....You gona try to post another thread in So Cal?
  14. Jul 12, 2023 at 2:16 PM
    #94
    Smcsherry
    Stephanie
    San Diego, CA, US
    2018 tacoma sr5
    I'm just like screwed I guess I asked for help a couple of times
  15. Jul 12, 2023 at 2:27 PM
    #95
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Hey Steph...do you know how to loosen the fuel rails?...not remove them just loosen the bolts so they will wiggle a little..if both rails would move just slightly ,that might give you what you need to get the line on
    Steves104x4 likes this.
  16. Jul 12, 2023 at 2:32 PM
    #96
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Wow, sorry to see this. Shit.
    HondaGM likes this.
  17. Jul 12, 2023 at 2:35 PM
    #97
    Glaese
    Glaese Unknown Member
    Country of Texas
    17 Sandy Taco Ltd
    My vote is replace the part due to seating importance. A little more expensive but a lot more peace of mind
    Smcsherry[OP] likes this.
  18. Jul 12, 2023 at 2:49 PM
    #98
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    dang. i know me. i would try to loosen the other end somewhat being VERY careful not to disconnect it. i bet that gives you wiggle room to get the other side started.
    Flare end wrenches are the correct tool. those fasteners are on the softer side to assist with sealing IIRC.
    OP. you need to put it altogether yourself? you are a badass!!
  19. Jul 12, 2023 at 3:45 PM
    #99
    Smcsherry
    Stephanie
    San Diego, CA, US
    2018 tacoma sr5
    I would just loosen these correct ?
  20. Jul 12, 2023 at 4:19 PM
    #100
    Chew
    Chewy
    Midwest
    19 TRD OR
    You know what?
    Some auto parts stores have tool rental,,, many are free, just buy something and leave a deposit.
    Can you call around and see if they have a “crows foot” socket in what size you need?
    Do you or anyone know what size it is?
