Fuel line for Diesel heaters
Discussion in 'Ontario, Canada' started by OverlandMark, Nov 15, 2023.
  1. Nov 15, 2023 at 9:49 AM
    OverlandMark
    OverlandMark [OP] Active Member
    2023 tacoma TRD sport
    Just an FYI if you have a vevor (etc) diesel heater I found certified fuel rated hose 3/32" (2.38mm) ID x 3/16"OD, 100psi (690kPl, 9bar)) at Home Debit, . It's in the plumbing department beside the white nylon hose. It's easier to bend than the white nylon hose and it won't kink, but the material is far less compressible than the cheap soft hose that come with most diesel heaters. Made by Canada Tubing Products, part # SUFD10, it was less than $10 for 10' (3m). I tried heating the line to see if it would slip on, it won't, so you will still have to get attach the same way as in John McK's excellent YT videos.
  2. Nov 15, 2023 at 3:41 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  3. Nov 16, 2023 at 6:54 AM
    OverlandMark
    I though it might be too small but 2mm ID is what is said in this vid.
    Also I measured the fuel pipe on my new 8K (really 5K) heater and it is 2mm ID.
    https://www.youtube.com/watch?v=jCZhjGyR3bo
    I also took 1m section of the tube, cut some slots into the one end, slid a section of electricians fish tape (wire) into it, affixed the red tube from a Fluid Film spray can on the other end and then used the spray nozzle on a can of PB Surface Shield. This easily feed into the drain and/or bump stop holes of the doors, pushed it in straight in as far as it would go, started the spray. It takes a few seconds to start to spray but when it does you can really hear it transition from air to spray and you then slowly pull out the tubes spraying as you go. I do have a more pro undercoating gun with attachments, but with this small tube and can method I can get into small body drain holes with no drilling. The wire is so the tube stays straight when you feed it through a hole.
    So far I've only done two doors and will post the results of the complete rust proofing job when I'm done.
