Fuel Line Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Needahand, Apr 3, 2024.
  1. Apr 3, 2024 at 11:42 AM
    Needahand
    Needahand [OP] New Member
    2008 Tacoma TRD Sport
    I have a 2008 Tacoma TRD sport that recently developed a fuel line leak at the first connection forward from the fuel tank. This is the connector that is disconnected when you drop the tank. It is approx. 2 drops every 10 sec and it is at the male / female "plug in" type connector. Can this connector be replaced or do I have to purchase the line beginning at the fuel pump outlet up to the first connection point. I can purchase the fuel pump discharge line assembly online, but I cannot find just the female connector. I can find after market Doman quick connectors but not sure if they will fit properly
  2. Apr 3, 2024 at 12:26 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    You could try disconnecting and cleaning it up and then reconnect. It might at least buy some time.
    1schoir likes this.
  3. Apr 3, 2024 at 4:29 PM
    Waasheem
    Waasheem
    2007 xrunner
    Did the connector get messed with recently? I’m agreeing with fixnfly, it might have dirt or debris in it. Try blowing it clean, disconnect, clean it out really good, maybe some wd40.
