Fuel line leaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03taco, Dec 5, 2022.
  1. Dec 5, 2022 at 10:32 PM
    03taco
    03taco [OP] Well-Known Member
    Alex
    2004 Taco
    Never Ending Project
    Hello everyone,
    After solving another issue noticed that the fuel line on driver side is leaking. See picture to the one I’m referring. 174FA690-8410-4CB7-901C-5B39926A399F.jpg
  2. Dec 6, 2022 at 5:15 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Vehicle fires are not fun!!
    Get that fixed ASAP!!
    Area51Runner likes this.
  3. Dec 6, 2022 at 9:19 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    03taco[OP] likes this.
  4. Dec 6, 2022 at 9:29 PM
    O'Silver_Taco
    MD
    Be careful with that.....mine was leaking.....so I thought I'd loosen and reseat.....
    yeah that was a big mistake.....
    Who ever did mine last cross threaded/stripped the bushing going into that rubber fuel hose....
    one time cinch .......after that never seals right...
    every time I tried to reseat.....gas just poured out even more.....
    And then trying to take it a part couldn't take the bushing out....stripped the female end......spin in place and refuse to separate...
    had to take dremel and cut it all apart.....what a pia.....
    Turns out the threads were damaged on bushing.....and would chew up what ever you screw it in...on new hose it would jump threads within half a turn....and crooked angle after that....
    So had to needle file that bushings threads right where they start....
    That fuel hose 2rz/3rz cost me $216.....from yotashop.com
    only one in the country at the time.....
  5. Dec 6, 2022 at 9:48 PM
    O'Silver_Taco
    MD
    There was a thread not too long ago where a 5vz replaced the two rubber fuel hoses with stainless braided ones....using adaptors and universal banjo connectors....
