Fuel lines capacity question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wilsonpj, Nov 18, 2009.
  1. Nov 18, 2009 at 12:51 PM
    wilsonpj
    wilsonpj [OP] Well-Known Member
    Pete
    Boulder, CO
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    I'm wondering how much fuel is held in the lines from the tank to the injectors. So if I use 85 octane then fill up with 91, how long until the engine gets the better gas?
  2. Nov 18, 2009 at 12:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I never checked to see how much it held, volume wise, but it seems it will idle for about 5 mins with what is in the line.
  3. Nov 18, 2009 at 12:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mostly, when the pump has nothing to push, the engine dies. Im sure there is still a bunch of fuel in the lines after that....Seems to be when you disco one onayway. :eek:
  4. Nov 18, 2009 at 12:56 PM
    wilsonpj
    Pete
    Boulder, CO
    2006 DC, SB, OR
    yea I couldn't see it being more than a half gallon max.
  5. Nov 18, 2009 at 1:04 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You would be lucky if there was even a quart in there.
  6. Nov 18, 2009 at 1:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think this is correct.
  7. Nov 18, 2009 at 2:27 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I say about on your third tank full before the 91 stops getting diluted with the 85.
  8. Nov 18, 2009 at 3:53 PM
    JKD
    JKD Well-Known Member
    If the fuel line is 0.25" inside diameter, and there are 10 feet of it from the tank to the injectors, then there is about 0.1 gallons between the tank and the injectors.
  9. Nov 18, 2009 at 4:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks....I never wanted to do the math. :eek:
  10. Nov 18, 2009 at 4:25 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    if your on "e" and u fill up with premium, you will see the differance in that tank.i have.
  11. Nov 19, 2009 at 10:05 AM
    wilsonpj
    Pete
    Boulder, CO
    2006 DC, SB, OR
    Yea I notice a difference, just curios how much fuel is in the lines, like chris I'm too lazy to do the math.
  12. Nov 19, 2009 at 10:41 AM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    Correct me if I'm wrong but I heard it will take at least a tank full before your ECU even adjust to which gas you're using.
  13. Nov 19, 2009 at 12:13 PM
    wilsonpj
    Pete
    Boulder, CO
    2006 DC, SB, OR
    I would highly disagree with that. When I start up my engine at my house of altitude 5500 feet and take a drive into the mountains up to 12,000 feet the engine must adapt. The MAF and ECU are constantly monitoring conditions.
