fuel low light out
Discussion in '1st Gen. Tacomas (1995-2004)' started by loudgonzo, Sep 17, 2010.
  1. Sep 17, 2010 at 7:32 AM
    loudgonzo
    loudgonzo [OP] Member
    low fuel light not coming on when the gauge drops low, drove it for a while afterwards and still did not come on. is there a fuse for this light, or a bulb? How do you access the bulbs behind the dash (check engine, fuel, speedometer etc?)
    thanks
  2. Sep 17, 2010 at 7:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Not sure how to go about replacing the bulb, but there isnt a fuse. Is the gauge working fine?
  3. Sep 17, 2010 at 7:40 AM
    loudgonzo
    i think it is now, last week when i filled up the tank, the gauge did not go all the way up to full, stayed between 3/4 and full, although the tank was full. After driving the tank to near empty, the gauge dropped down empty, but the low fuel light did not come on.
  4. Oct 10, 2010 at 8:14 PM
    thebaugh23
    thebaugh23 Member
    Eston
    blueridge mountains
    99 TRD 4cyl ex-cab
    3" ToyTec lift. keyless entry/ alarm. XM radio. westing burshguard, super 44 flowmaster, tinted windows, A/T tires, New Bilstein HD shocks
    mine doesnt either. i was wondering how to fix it cause my fuses are good. but i had an 89 that never came on either
  5. Oct 11, 2010 at 7:05 AM
    loudgonzo
    The gauge works fine, have done a good estimate from a full tank to how many miles driven.
    Just the low fuel light is not lighting when gauge is low.
    Any help appreciated.
  6. Oct 11, 2010 at 7:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    Here is how you can check it.
    To get the cluster out...........
  7. Oct 11, 2010 at 7:49 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The dash is kinda a pain if you have never done it before just follow the instructions 98tacoma27 posted and you should be fine. You just have to remember the panels will come off fairly easy so if it's not you probably have a screw somewhere. wile your at it when you have the gauges out you can change Orange gauge lights if you want I changed mine to LED's but you can just take off the Orange rubber cover on the bulb and it would look better.
    NOTE:
    You cant change the color of your indicator bulbs (Check Engine,ABS,Locker,Blinkers) there's a coating on the gauge face itself believe me I tried so your SOL on that one.
  8. Oct 11, 2010 at 11:05 AM
    crimsonred2004
    crimsonred2004 X-wing Design Engineer
    Bob'O'
    MI
    02 Limited TRD Xtracab V6 4X4
    Did this light ever come on when you turn the ignition to on??? most of the others do when ya do this...almost seems like a bulb test before ya start the truck....
  9. Oct 11, 2010 at 8:40 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Have you ever seen it on? I questioned mine working too but it doesn't come on till very low
  10. Oct 11, 2010 at 9:39 PM
    tacosuprem
    tacosuprem Well-Known Member
    Florida
    4x4
    Why would you drive till the light is on? Get gas and then your problem will be fixed.................
  11. Oct 11, 2010 at 10:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Are you guys certain you even have a light? According to the thread at the link below, its not uncommon for '98-'00s to not have one. Check out post #11. EnolaGaia is never wrong about such things. just sayin...
    http://www.tacomaworld.com/forum/1st-gen-tacomas/68046-gas-light-wont-go.html
  12. Oct 12, 2010 at 5:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    My 98 didn't have one.
  13. Oct 12, 2010 at 5:40 AM
    loudgonzo
    do you have pictures? what leds did you use, can you provide a link?
  14. Oct 12, 2010 at 5:41 AM
    loudgonzo
    yes, there is a light, seen it on more than I should, but I know it has it.
  15. Oct 12, 2010 at 5:45 AM
    loudgonzo
    Not in a habit of driving till light comes on, though I've done it quite a few times for a number of reasons. But the fact that I know something is not working makes me want to have it fixed.
  16. Oct 12, 2010 at 7:52 AM
    98tacoma27
    Ben
    Not Beech Creek
    Well, turning the key to the ON position initiates the bulb check. If the low fuel light illuminates at that time then it is the sender in the fuel tank. If the light doesn't come on, it's the bulb.
  17. Jan 22, 2011 at 2:54 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I am working on getting the dash out of my Tacoma and pulled the cluster. I noticed that there was a spot for a "low fuel light". I would LOVE to have one of those. my 87 4runner has one too. Has anyone figured out if I put a bulb in it will it work, or is there a sending unit difference?
    My Tacoma is a 99 Tacoma 3rz 4x4 sr5. (started life as an Auto, but is now a Manual... if that matters)
  18. Jan 23, 2011 at 3:01 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    Just to add to this thread, I pulled out the Wiring diagram from my truck and found the fuel light in the circuit. It says the "fuel light" wire is Y-B (yellow w/ a black tracer). I started at the fuel pump. I found the pump to have 4 wires coming from the top. One was Y-B. So went back to the harness at the cluster. I looked but found that the slot that the wire uses was empty. I went back to the fuel pump and traced the harness back up the frame rail to where it goes into the cab under the driver's seat. There under the seat is a white plug. One side of the plug you see the Y-B wire going in but there is not one going out. If my hunch is right, all you would nee is the 2 pins for the harness and one wire connecting the pluh under the seat to the cluster plug to make the light work!!!
  19. Jan 23, 2011 at 3:12 PM
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    mine comes on when the needle is past the E.
  20. Jan 25, 2011 at 5:12 PM
    2001boston
    2001boston Member
    Boston
    tacoma
    Same here, I used to rely on the low fuel light I knew once it came on I had about 20 miles to get to a gas station......until it didnt come on and I ran out of gas on the highway, at rush hour, with no breakdown lane to pull over. Nothing more embarasing than standing outside your truck while a towtruck driver fills up your gas tank.
    Let me now how you make out
