Fuel Milage for your 2nd Gen Taco..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by perchie15, Sep 12, 2013.
Fuel Milage
  1. 8-10mpg
    5 vote(s)
    0.4%
  2. 11-13mpg
    51 vote(s)
    4.1%
  3. 14-16mpg
    286 vote(s)
    22.7%
  4. 17-19mpg
    605 vote(s)
    48.1%
  5. 20-22mpg
    238 vote(s)
    18.9%
  6. 22+
    73 vote(s)
    5.8%
  1. Jan 6, 2014 at 2:04 PM
    #441
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    average went up to 24 after my last fueld up
  2. Jan 10, 2014 at 8:23 PM
    #442
    Pete838
    Pete838 Active Member
    Pete
    Ocala, FL
    08 PreRunner Double Cab 4x2
    Bilstein 5100 shocks, Toytec Eibach coil springs, Toytec AAL, Chrome 4" step bars, Pioneer AVIC X910 stereo, Polk speakers, Leather seats
    I've read the last couple pages of this thread and haven't noticed anyone mention speedometer correction when calculating fuel mileage. If someone already did I'm going to reiterate.
    For anyone running over or undersized wheels/tires, remember unless you've had your speedos corrected either by calibration or with a module it is wrong, and that affects your odometer, and your odometer affects your fuel mileage calculations.
    Under sized tires or wheels have to turn more rotations to get you the same distance and will give you an overly rosey reading on mpg. Oversized tires travel farther with each rotation and will give you an incorrectly low reading. There are correction multipliers you can use if you know your original tire size and new size.
    My mostly stock Prerunner Tacoma with stock tire outside diameter and mostly highway driving 65-75 mph with a little bit of city driving gets 18.5-19.2 mpg reliably. If I idle a lot or push it it drops to no less than 17. I currently have 180,000k miles on her.
    Pulling trailers it drops like a stone. 400 miles pulling a 6x12 enclosed uhaul trailer netted 11.2 mpg, and I average about the same pulling a pontoon boat or my company's Bobcat on a tandem axle trailer.
  3. Jan 10, 2014 at 11:36 PM
    #443
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Garmin GPS used for miles actually driven, input gallons used = magic number.
    makes life easy for me :)
  4. Jan 11, 2014 at 12:35 PM
    #444
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    To add to what Pete said - it even happens with oem tires. As they wear, they become undersized, and give less accurate mpg. My dunlops were a full inch less in diameter when replaced at 37,000. If you don't use GPS, check your odometer against 50 miles by mile marker at least every 10k miles to determine odometer error.
  5. Jan 12, 2014 at 10:36 AM
    #445
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    '07 base taco. Sold. Now Taco-less
    Factory cruise added, wood storage box in bed, wood center console/armrest, charcoal air filter delete.
    Most of Florida has high humidity which, like high altitude, reduces the amount of available oxygen per cubic foot of air. The humid air is denser than high altitude air so there would be some extra aerodynamic drag. The barometric pressure sensor knows there's less air pressure at high altitude, there's no humidity sensor so adjustments rely on the O2 sampling. In the warm humid climate most people will run their A/C all the time, not so much in the mountains. When my Taco was in Miami it averaged 18MPG, in L.A. I'm getting 20+. If I didn't drive 80+MPH every time I get on the highway I'm sure it'd do better. In Miami it was my dad's truck so different driver, but he didn't hot-rod it or haul cargo. The only things he did that would negatively impact the mileage is running the A/C and running the tires at lower pressure for the softer ride. I run the tires high and the A/C only when it's stupid hot. We both ran the cheapest gas available and I probably average 5-10 MPH faster average driving than he did and have more hilly terrain. His traffic on average was probably only a little shittier than mine. His cold starts were usually 80+ degrees, mine much lower, and I've seen a big mileage difference in driving a cold engine vs. warm.
    Living in Florida as well as mountains are two extremes compared to most of the country. I'm guessing that if someone took the time to analyze MPG differences across the country we'd find that driving in either extreme reduces fuel efficiency.
  6. Jan 12, 2014 at 10:42 AM
    #446
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    And speedos are rarely accurate at any point within a tire's life. Around here we have a few radar speed indicators that show your speed as you drive by and none of my speedos have been right. Most read on the high side and some by up to about 10% on completely stock vehicles.
  7. Jan 12, 2014 at 4:13 PM
    #447
    bzzr2
    bzzr2 Well-Known Member
    here is the key - ethanol free gas - it's pretty much impossibly to find that around here, would be great.
  8. Jan 12, 2014 at 4:21 PM
    #448
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    pure-gas.org has listings for most states plus Canada including marinas and airports
  9. Jan 12, 2014 at 4:21 PM
    #449
    "OldManTan"
    "OldManTan" Now my Taco is bloody Red, ewww
    Buffalo, NY
    08 Access Cab, Radiant Red
    Pioneer HU, Duratracs on Black stockers, Century topper with custom electronic lock, Illuminated 4x4 switch, Foglight Mod, Always on 12v Plugs, Sub & Amp, LED Interior Lights, Cup Holder Mod, Andres Devil Horns, CB radio, steps, relocated trailer harness, blacked out everything!!
    No location listed so don't know where "here" is.
  10. Jan 12, 2014 at 5:28 PM
    #450
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    A lot of those are wrong too.
    The set coming back from the Barstow area on I-15 read 5+ higher than actual.
    Likely intentional, trying to slow down the Vegas traffic returning. I've never seen a Caltrans speed sign THAT far off before.
  11. Jan 14, 2014 at 8:32 PM
    #451
    Communistwookie
    Communistwookie Member
    Columbia, SC
    2007 Toyota Tacoma AccessCab PreRunner Sr5
    Borla Intake, Exhaust
    Pulled 21.23 mpg highway 70mph like this :). Guess its the ethanol free gas that does the trick
  12. Jan 14, 2014 at 8:41 PM
    #452
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Or the communists passing down free mileage per your screen name.
  13. Jan 14, 2014 at 8:47 PM
    #453
    Communistwookie
    Columbia, SC
    Haha, I wish.. Maybe then my supra would do better than 18mpg.
  14. Jan 14, 2014 at 8:49 PM
    #454
    Boone
    Boone, NC
    Airbags deployed
    And maybe my LT4 would get more than 4mpg.
  15. Jan 23, 2014 at 9:41 PM
    #455
    robm7
    robm7 Well-Known Member
    2012 S-W DCSB TRD OR
    I get 16ish on Blizzaks
  16. Jan 24, 2014 at 7:12 AM
    #456
    6172crew
    6172crew Well-Known Member
    New Mexico
    4X4 TRD sport
    Everyone should mention if its a 2WD or 4WD, I think thats the huge difference. No way my 4wd double cab can see 20mpg
  17. Jan 24, 2014 at 11:00 AM
    #457
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    3/4 tank burned on my new 4wd double cab long box V6, 19.33 mpg. That was 95% highway.
  18. Jan 24, 2014 at 2:30 PM
    #458
    Menj309
    Menj309 Well-Known Member
    Richard
    SoCal 909
    13 trd sport
    CB Radio
    I think the mods should be mention too.
  19. Jan 24, 2014 at 2:37 PM
    #459
    Aromeo620
    Aromeo620 Active Member
    Anthony
    Boston, MA
    Toytec 3" boss Coilovers with an AAL
    2011 double cab v6 4.0 4wd, afe intake getting almost 16 mpg's! Mostly highway some city but Running 285/70/17's with a 2.5" leveling kit
  20. Jan 24, 2014 at 2:51 PM
    #460
    GreatCanadian
    Newfoundland
    SR5 4X4 V6
    Ok. 2nd fill up. 75/25 highway/city. 12.8 MPG. WTF??? That's NOT aggressive driving. And yes its calculated properly. Been doing this for years on all my vehicles. That ain't gonna do!!
    Edit to add: 2014 V6 Auto Double Cab 4x4.
