Fuel Milage for your 2nd Gen Taco..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by perchie15, Sep 12, 2013.
Fuel Milage
  1. 8-10mpg
    5 vote(s)
    0.4%
  2. 11-13mpg
    51 vote(s)
    4.0%
  3. 14-16mpg
    287 vote(s)
    22.8%
  4. 17-19mpg
    606 vote(s)
    48.1%
  5. 20-22mpg
    238 vote(s)
    18.9%
  6. 22+
    73 vote(s)
    5.8%
  1. Feb 5, 2014 at 1:54 AM
    #541
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    I guess you could just move far.....far.....far away from the depraved armpit of humanity you call home.
  2. Feb 5, 2014 at 4:12 AM
    #542
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    '07 base taco. Sold. Now Taco-less
    Factory cruise added, wood storage box in bed, wood center console/armrest, charcoal air filter delete.
    Or about 70% accurate. I'm not bashing just so you know, it's just frustrating to see skewed information like this being posted.....my OCD perhaps. The inaccuracy isn't in the calculations or the app, it's in targeting an even dollar amount. For consistent calculating you need to fill the tank 'till it clicks off and stop. It still won't be 100% accurate because the pumps won't always click off at exactly the same fuel level, but it's as close as we can get. The extreme changes in mileage aren't your driving habits, they're your fueling habits. BTW, if you fill 'till it clicks then keep adding to reach an even dollar amount you could do damage to your truck.
  3. Feb 5, 2014 at 4:43 AM
    #543
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    Could you please explain this. Since I bought my new truck I have NOT been doing this. But on all vehicles up to this one I've always pumped until it clicked off, then pump-click off, pump-clickoff, until I couldn't get another drop in the tank. How does this damage the truck? I'm not saying it doesn't, as it's only lately that I've come across this information. Just wondering how. Thanks.
    GC
  4. Feb 5, 2014 at 5:10 AM
    #544
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    its because new vehicles in the US have a charcol canister that if you overfill, gas gets into it and ruins the canister eventually.
  5. Feb 5, 2014 at 5:10 AM
    #545
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Okay.... then it becomes...
    10.00 Gallons
    $24.99
    Same dilemma ;)
  6. Feb 5, 2014 at 7:32 AM
    #546
    GreatCanadian
    Newfoundland
    SR5 4X4 V6
    Thanks for that, it's someting I did not know!! You say "in the US", but I assume Canadian tacos have the charcoal canister as well?
  7. Feb 5, 2014 at 8:43 AM
    #547
    lloyd
    lloyd Active Member
    Texas
    15 Tacoma Access 2.7
    HID headlights, LED interior lights, Hella and stock HID foglights, Hella HID driving lights, backup camera, Wiper mod, cruise control mod, higher rate springs , X- runner Rear rollbar and x-brace, K&N air filter, Amsoil in trans and diff, EBC yellow stuff pads pads, stainless brake lines, 18x8 40mm wheels with 235 55r 18 tires, oil cooler with remote big oil filter
    I have a 2013 Access cab with the 4-banger. My ultragauge shows 24.0 MPG average for around 6,000 miles. That is a mix of fast freeway and city stop and go. I commute 40 miles each way to work in a big city.
  8. Feb 5, 2014 at 9:32 AM
    #548
    bvlpxm
    bvlpxm Well-Known Member
    pat
    Upstate South Carolina near Spartanburg but have l
    2014 DCSB TRDsport 4x4
    AVS vent shields & bug deflector - Floor Mats - AVS sill protectors- Gentex K51a auto dim,temp, compass, homelink - OEM Bedmat - Pulled TRD Sport decals-frame undercoat - DU hitch cover- Gloss black high temp paint Brake Drums, Calipers, Muffler back exhaust - OEM Bedmat - CK Neosupreme Seat covers
    only 2nd fill up & check on a new 2014 4x4 DCSB 6cyl auto. 1st check was 17.2mpg, 2nd was 17.67mpg. still less than 1000 miles hopefully it will get a little better. about 50/50 highway city split.
  9. Feb 5, 2014 at 9:35 AM
    #549
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    My 2014 is around the same in those cold temps, should be in the 20-22 range for summer. I'm had it up to 19.5 on my first tank in November and then the cold hit:rolleyes:
  10. Feb 5, 2014 at 11:20 AM
    #550
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Have been filling to the top for almost 5 years and 46k miles, tank will take up to 2.5 gallons from first shut-off. BUT I also drive at least 20 miles immediately, burning at least a gallon, and have had no codes/problems. Have put in as much as 21.3 gallons.
  11. Feb 6, 2014 at 6:40 AM
    #551
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    You can get away with overfilling some, and immediately using it helps. It can not only damage the charcoal canister but other things as well. It might take an extreme overfill depending on how the tank and lines are set up, but overfilling can result in nothing at all or all the way to a ruptured tank--tho very unlikely. Fuel could also get into the evap. purging lines and mess with stuff. Gas pumps aerate the fuel and most tanks' inlets are on the side, both of which make it more difficult to overfill, but I just don't see a reason to tempt fate. Tank capacity ratings are usually at 85%-90% of full so you can go past the rated capacity some before actually filling the tank to the top which is the point where damage becomes likely.
  12. Feb 6, 2014 at 8:09 AM
    #552
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    There are countless variables that could affect a vehicle's fuel economy: ethanol or pure gas, startup temps and warmup habits, acceleration habits, idling periods, hill climbs, tire sizes, tire pressures, condition of alignment, condition of engine tune, excess weight/load carried, headwind/tailwind, fillup station pumps may be inconsistent, filling habits (stop at click or top-up)... this list could go on forever.
    So anyone's ridiculous mileage claims or swings in mileage numbers are all plausible, to a point. Nobody's getting 40mpg from these trucks, unless they are verified 100% insanely OCD, and their driving would probably be a danger to others anyway.
    I'm just saying, some people on here think they know everything about a driver's habits and situation, but they don't. Yes, proof would be great, but that's just not gonna happen for every post in this thread.
  13. Feb 6, 2014 at 8:21 AM
    #553
    BillyFargon
    BillyFargon Well-Known Member
    Oregon
    2001 Tacoma
    I have a brand new 14 dc short bed, 4x4 trd OR and my first tank was 16.4, 2nd was 16, and now this third one was 15.5!!! I have less than 1000 miles on truck and this is really disappointing!
  14. Feb 7, 2014 at 10:24 PM
    #554
    Big Wave Dave
    Big Wave Dave Member
    So ..... Any real tips on boosting mileage? I'm not off roading or drive like a maniac. Driving a 2014 double cab 2 x 4 with the 17" wheels. I have nothing to prove. Just love the truck and want better gas mileage. Suggestions?
  15. Feb 7, 2014 at 10:36 PM
    #555
    Rich91710
    Rich
    Los Angeles
    08 Base
    Drive like there's an egg between your foot and the pedal.
    Both pedals.
    Hard braking is an indication that you have already wasted energy. Look ahead, anticipate slowdowns and ease up on the gas to increase your following distance.
    Air resistance works against MPG when you're on the go, but it can be your friend when you are slowing down, making for a more relaxed, comfortable drive, and saving your brakes.
    But.....
    Get into high gear quickly. Don't accelerate like John Force, but don't "nudge" it up either. Your most efficient speed is 5-10mph above where you just drop into overdrive.
    Going slower and spending more time in lower gears, you are running more revs per mile, and every rev gulps 2.7 or 4 litres of air and fuel.
  16. Feb 7, 2014 at 11:10 PM
    #556
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Half that. ;)
  17. Feb 8, 2014 at 6:28 AM
    #557
    lloyd
    lloyd Active Member
    Texas
    I air my tires to 40psi
  18. Feb 8, 2014 at 7:04 AM
    #558
    Big Wave Dave
    Thanks Rich and Lloyd. I've got my tires at 38 I think and being that I drove a manual Corolla before this (see why I'm concerned? LOL!) I'm used to anticipating stops and coasting. So far getting 17 in town. Wish I could get a couple more. I did put a topper on. Wonder if that helps or hinders?
  19. Feb 8, 2014 at 9:11 PM
    #559
    Big Wave Dave
    Any truth to the claims that the K&N or AFE air filters increase mpg? And I saw a review that said the tacoma's air sensors don't do well with the oiled/wet filters. Yes, no? Which one? Thanks.
  20. Feb 8, 2014 at 9:17 PM
    #560
    Rich91710
    Rich
    Los Angeles
    08 Base
    No improvement.
