fuel milage mud terrain vs. all terrain
Discussion in '2nd Gen. Tacomas (2005-2015)' started by das56170, Jul 8, 2008.
  1. Jul 8, 2008 at 12:54 PM
    das56170
    das56170 [OP] Well-Known Member
    Orange County
    2007 Tacoma Access Cab 4X4 SR5 (sold), 2002 Tundra Access Cab 4x4 SR5, TRD Offoad
    Tacoma - Flowmaster cat-back exhaust, volant cold air intake, 3" lift with AAL, 285/75 r 16 pro comp xterrains, 1" differential drop, spare tire mod, hypertech in-line speedometer calibrator, debadged
    I'm currently running 285/75 r16 pro comp xterrain mud tires. They came with the wheels that I got. The fuel economy isn't as bad as I thought it would be. I was wondering what the difference in mpg's would be if I switched to BF Goodrich All terrains. Would it be just a small improvment or more? I like the look of mud terrains and will stick with them if all terrains will only help a little?
  2. Jul 8, 2008 at 12:55 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    they both are very heavy tires, A/T might be a tab lighter but its a bfg, they weight the same as the pro comps...
  3. Jul 8, 2008 at 8:15 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    you woudlnt notice it unless the size was different.
  4. Jul 9, 2008 at 2:21 AM
    Greenblazer
    Greenblazer Thread Killer
    Phoenix. Aridzona
    07 PreRunner Dblcab SR5 Black
    Home Made Tonneau, The Baba Booey Mod... Sirius Satellite Radio
    If you put on a heavier tire you will pay for it at the pump for sure, rolling resistance and aerodynamic changes will have an effect on fuel economy too. Running your tires at maximum sidewall pressure will improve FE, but will make it ride a little stiffer.
    Later,
    Allan Greenblazer
  5. Jul 9, 2008 at 4:10 AM
    rio112
    rio112 New Member
    Germany
    Landrovers
    LR 110TD5 Station Expedition LR 90TD5 Softtop LR Series2 Softtop Build 1958
    i think its also a question of "whre do you wanna go?"
    do you really need pure MTs ?
    I drove the BfG ATs on a offroad course, and wonderd how far they gone,
    also in the snow.
    those tires are very quite on the steet.
    currently i use cooper discoverer st, and to me its the best choice, cause
    i drove on sandy beaches in greece, in the snowy alps and in the muddy black forest in the wintertime without damage and a good performance.
    it a 50/50 tire
    probably is this an option for you...
    (the mpg is simular to the ats)...cause you can drive the st with a higher pressure on the road....
    greets
    rio
  6. Jul 9, 2008 at 4:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You won't notice the difference.....just not much difference at all in weight.
    I'd be more concerned with drivability in wet/snowy weather. If you are happy with the Xterrains in the wet/snow - then stick with them. Don't assume all M/T tires are gonna ride the same in those conditions - as you might be disappointed. A/T tires are a GREAT all around daily driving tire for all sorts of conditions and tend to be better in wet/snow than any M/T tire.
    Play it safe.... get A/T's.
  7. Jul 9, 2008 at 7:01 AM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    to add... you don't have to go with BFG's either. I have a set of Toyo Open Country A/T on my truck and I like them a lot more than the BFG's A/T's that came on the truck when I bought it. They seem to do a bit better in the snow as well than the BFG's but I don't hit snow all that often.
  8. Jul 9, 2008 at 7:05 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    did u buy the truck used to have the a/t's on it?
