Fuel mileage issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Schenko, Jun 21, 2012.
  1. Jun 21, 2012 at 10:18 AM
    Schenko
    Schenko [OP] Member
    texas
    03 prerunner SR5 TRD
    this doesnt really count as a mod but i figured id say in this section that ill put up some pics of my truck after it gets fixed. some guy decided to turn into me and ruined the whole passenger side. truck is so tough the window and locks and door still work fine.
    Hey guys I have another question for you. For some reason this past full up my fuel mileage dropped from roughly around 22 mpg to about 14-15 mpg. It's an 03 prerunner with a 3.4 any ideas?
  2. Jun 21, 2012 at 10:59 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Could be that you drove more aggressively, poor gas, or bad 02 sensor, but there are so many reasions for it.
  3. Jun 21, 2012 at 11:56 AM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Heh, just ONE fillup?
    I will say this: usually the simplest explanation is the correct one. Last time you didnt fill it up all the way.
  4. Jun 21, 2012 at 1:31 PM
    Schenko
    Schenko [OP] Member
    texas
    The difference was in one fillup. I filled up my tank drove home and noticed right off the bat that my gauge dropped further than usual and I always reset my trip odometer when I fill up just invade something like this happens. I wasn't driving aggressive and infact I noticed after today when I had to get on it a bit it started getter gas mileage again. Now I'm think maybe a fuel filter or something. Any thoughts? I'll post what's find out just invade this happens to anyone else
  5. Jun 21, 2012 at 2:05 PM
    Madjik_Man
    Colorado Front Range
    Proper tire inflation?
  6. Jun 22, 2012 at 5:05 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    It is now *conclusive*. You definitely need to pay more attention when filling the tank. Sometimes the handle will shut off before the tank is full. YOUR TANK WAS NOT FULL!!!!
  7. Jun 22, 2012 at 5:16 AM
    elytravis
    elytravis Well-Known Member
    Travis
    Always changing...but there is no place like home.
    2012 Nautical Blue DCLB TRD Sport
    Black tube steps, Skid plate, Bilstein 6112's front and 5160's rear, Bakflip F1 folding cover, EGR raingaurds, All weather floor mats, AFE pro dry filter, BFG 265 70 R 17 KO2's.
    I have a second gen and live in Ne, but I just completed some personal research on the local fuel. We have ethynol fuel here and using 91 octane with no ethynol outside of Omaha from shell, I can get 22.5 MPG using 89 with ethynol I get about 15 MPG. 87 without ethynol 19 MPG and 91 which dosen't say it has ethynol (which I don't believe because I am in Nebraska) still gets around 15 16 MPG. So a long story short it may simply be the quality of gas for that single tank. I was amazed to see my milage go from 22.5 MPG to 15 MPG in just one tank. The Gas station makes the difference, but I wouldn't be concerned from one tank if the poor mileage is not consistant. Time will tell.
  8. Jun 22, 2012 at 5:28 AM
    Andreas
    Andreas Well-Known Member
    Andreas
    Salt Lake City
    '02 Limited SR5 TRD Stepside
    Ethanol additive in the fuel will do it too
  9. Jun 22, 2012 at 6:06 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I don't think ethanol would kill your mileage over 30%. I think we have 10% ethanol in our gas here in California and I get around 22 on the highway in my V6 4x4.
    The assertion that your tank was not completely full on the last fillup makes the most sense to me.
  10. Jun 22, 2012 at 10:14 AM
    elytravis
    Travis
  11. Jun 22, 2012 at 12:06 PM
    Gooch
    Orange County CA
    If the only thing the OP noticed was MPG, I doubt it was the fuel.
    Again, we're talking about a hit of over 30% in MPG. That's almost how much of a hit I take when I tow my boat. If the fuel was that low in energy, IMHO he would have noticed a difference in the way it drove.
  12. Jun 22, 2012 at 12:46 PM
    elytravis
    Travis
    Well I have flucuated from 15.1 - 22.6 and the only difference was the fuel, so you wont really know what the issue is until you get historical data. If the problem is consistant, it may be the truck.
  13. Jun 24, 2012 at 1:10 PM
    Schenko
    Schenko [OP] Member
    texas
    well my tank is almost done and im about to fill up again. i had poor fuel mileage the entire tank. also im positive i had a full tank from the beginning. i also noticed a lack in power. im right at the time to do an oil change and also change my air filter. im going to try to run sun fuel injector cleaner through. i just did a tune up a few months ago so i doubt its an ignition issue. im going to change the fuel filter as well and see what happens. first im gonna verify its not the gas by filling up again and see if it does it still.
  14. Jun 24, 2012 at 1:11 PM
    Madjik_Man
    You're filling up at different gas stations, right?
