Fuel Mileage on '24 Tacoma I-Force Max?
Discussion in '4th Gen. Tacomas (2024+)' started by JSFoster75, Jan 3, 2025.
  1. Jan 3, 2025 at 5:08 AM
    JSFoster75
    JSFoster75 [OP] Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    Anyone have real world numbers on the fuel mileage they are getting? I'm fixing to pull the trigger on one (I think), deal is in hand, just concerned that the fuel mileage will be like our new Land Cruiser and be 3-4mpg less than advertised...
  2. Jan 3, 2025 at 5:11 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    I would assume it would be exactly as you are experiencing with your LC until it learns more of your driving habits and slightly improves.
  3. Jan 3, 2025 at 5:14 AM
    JSFoster75
    Scott
    Bluff City, TN
    Too many to list.
    We are at 5,000 miles on the LC and it's holding steady at 19.6mpg using 93 Octane Fuel (required). It was advertised at 23mpg average fuel consumption... :(
  4. Jan 3, 2025 at 5:52 AM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Unless you drive a vehicle the way the EPA does then you will never achieve the posted milage. Check fuelly for real world numbers?
  5. Jan 3, 2025 at 6:33 AM
    Toyturckman
    Toyturckman Active Member
    Dave
    2024 Tacoma Hybrid Limited Underground
    None
    I’m getting 20.3 from new….But only have 520miles so far. Just filled up over the weekend 3rd tank.
    JSFoster75[OP] likes this.
  6. Jan 3, 2025 at 7:06 AM
    timetoeatpotatoes
    timetoeatpotatoes Well-Known Member
    2024 Bronze Oxide Trailhunter
    We have shit aero. Unless you keep your highway speeds under 65MPH you wont get epa numbers.
    At 65, flat highway, no wind, I get the 24. At 70 I'll get 22~. At 75 I'll get 20-21.
    Around town it's anywhere from 17 to 22 depending on how much stop and go there is.
    At 1500 miles my total average is like 20.
  7. Jan 3, 2025 at 7:21 AM
    dleithaus
    dleithaus Well-Known Member
    Washington State
    2024 TRD OR DCSB iForce Max
    TRD OR iForce Max.
    Front air dam removed. (For some reason you get one on the iForce Max; had dealer remove when purchased).
    A little over 2000 miles driven, 60-40 mix highway vs slower metro. 65-75 MPH actual highway speeds.
    Normal drive mode. No modifications.
    21.6 MPG, average display value, closely matching tank to tank calculations.
    It is a great drive, lots of low end torque and strong HP curve. (especially compared to my prior 2021 TRD OR).
  8. Jan 3, 2025 at 7:22 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Is 19.6 mpg your tank average for city driving?
  9. Jan 3, 2025 at 7:26 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Also highway mpg is usually calculated at 55mmph, which is 20 less than the average Joe is going on the freeway
  10. Jan 3, 2025 at 7:28 AM
    Mannino
    Mannino Active Member
    2023 Electric Lime Tacoma TRD OR 6MT
    Fuelly has (80) 2024 Tacomas being tracked covering 991 fill-ups over 240,665 miles. The community average is 19.5mpg. The following chart represents the spread. Obviously some way high ones don’t seem accurate, and some low ones may be driving style or modifications. This should at least give you real world ballpark numbers across the board.
  11. Jan 3, 2025 at 7:19 PM
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    I just did the math on mine and it got 16MPG over the first 1000 miles 80% not freeway a couple of hundred miles of towing some off road and snow at 5000 feet above sea level 10% ethanol Premium.
  12. Jan 3, 2025 at 7:27 PM
    wktjr1
    wktjr1 Active Member
    I'm willing to take the MPG hit just for the joy of driving it. I have the Limited hybrid and in Sport+, well, lets just say it's very impressive!
    PDKTaco, Flori-duh Taco and dleithaus like this.
  13. Jan 4, 2025 at 4:03 AM
    Lennyz1
    Lennyz1 Well-Known Member
    Len
    2024 TRD Sport Premium Hybrid 4x4 Bronze Oxide
    Got 1100 miles now and have been getting 21 MPG. Towing a small 10 ft single axle stake side trailer yesterday and the mileage was dropping like a rock. Probably somewhere around 16 MPG towing and the trailer was empty. I cannot imagine hauling a 6000 LB trailer down the highway.
  14. Jan 4, 2025 at 2:47 PM
    PEAKIT
    UT
    My raptor got better millage and made more power than my Taco does until its engine fell apart at 5k miles
    BlkTaco47, Kolter45 and JoeMongo like this.
  15. Jan 4, 2025 at 8:49 PM
    whtmtngrv
    whtmtngrv Well-Known Member
    SoCal
    2023 CSM TRD OR DCSB
    - Yota Xpedition Pro Style Grill - Yota Xpedition Black Emblem Overlays - Weathertech Bug/Rock Deflector - Cali Raised LED Cat Shields - Cali Raised Bed Stiffeners - Gold Hook Black TRD OR Bed Decals - TRD Pro Style Taillights - FitCamX Dash Cam - AJT Designs Nalgene/Yeti Cupholder - Fumoto F133N Oil Drain Valve
    I thought 23MPG was the highway estimate on the 2024’s? When I compared the 2024 TRD OR to 2023 TRD OR, it was published as 19 city/23 hwy and 18/22, respectively. A 23MPG average would be roughly 21 city/25 hwy? Unless you’ve got the hybrid motor.
    If the 2024’s are anything like my 2023 and every other car I’ve owned in my life, you have to be very judicious with acceleration, speed, etc to achieve the top MPG estimates, turbocharged 4-banger or otherwise.
  16. Jan 5, 2025 at 11:37 AM
    PEAKIT
    UT
    Because it has been a 3.5 TT for almost a decade.
    BlkTaco47 likes this.
  17. Jan 5, 2025 at 1:10 PM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    I get 17.0 in town, or highway only, in my 24 Pro. It fluctuates very little from 17.0 regardless of the type of driving I am doing. My Expedition, Lambo and Ferrari all get about the same, or slightly better, mpg.
    Flori-duh Taco and Charlie Too like this.
  18. Jan 5, 2025 at 1:40 PM
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
    Put it in tow/haul and turn off traction control by holding the button for 3 seconds. That really wakes em up!
    Hopehik and Flori-duh Taco like this.
  19. Jan 23, 2025 at 2:05 PM
    klctlc10
    klctlc10 Member
    K
    2024 Tacoma TRD Pro
    none all factory options
    I have the Pro and similar to Rob4092xx. I can get up to 17 in town if I feather the throttle and try to max fuel. Highway is similar. However, this cold weather has really hurt that. Down at least 2 mpg. Not thrilled with the mileage. I live in Illinois but spend a lot of time in northern Wisconsin.
    Fast1 and rob4092xx like this.
  20. Jan 23, 2025 at 4:54 PM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
    Winter blend gas is killer. Every year I watch the mpg's drop at around October through April.
    Kolter45, Shellshock and Charlie Too like this.
