Fuel Mileage on '24 Tacoma I-Force Max?
Discussion in '4th Gen. Tacomas (2024+)' started by JSFoster75, Jan 3, 2025.
  1. Feb 1, 2025 at 5:12 PM
    #41
    evlfred
    evlfred Member
    24 Limited iMax
    on my limited for the last few weeks it depends on the outside temp. When it was above 32 out, the battery warmed right up and it used the electric power more so I was getting about 22-23 around town. With the below zero temps it takes too long to warm up and rarely uses the electric power, so 19.5 around town. This is both in the truck computer and in the fuelly app, they are within a .1 of each other every time. On the highway last time I went to Colorado (about 500 miles each way) I was 25.2 there and 24.7 on the return with a lot of snow.
  2. Feb 2, 2025 at 8:47 AM
    #42
    Light1984
    Light1984 Well-Known Member
    24 TRD OR Hybrid Bronze Oxide
    19.7 combined for me. Chin spoiler delete and bypassed auto start/stop on ice. 93 octane.
  3. Feb 2, 2025 at 10:09 AM
    #43
    Lennyz1
    Lennyz1 Well-Known Member
    Len
    2024 TRD Sport Premium Hybrid 4x4 Bronze Oxide
    Benn doing some testing and I am finding better mileage on 87 octane. Both 91 non-ethanol and 93 10% ethanol have been returning about 1 MPG less than the 87 10% did. Tough this time of year because of winter additives.
  4. Feb 2, 2025 at 11:32 AM
    #44
    at4225
    at4225 New Member
    TRD sport 4x4 iforce max....I'm getting 16.5 mpg. I'm never peeling out and I don't think I have a heavy foot but yet I'm still getting the same gas mileage as my 3rd gen trd off-road.
  5. Feb 2, 2025 at 12:14 PM
    #45
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Getting 20-24 around town and I feel like I won the lottery compared to prior Tacomas (3), FJ, and 4R…Power on demand + mpg, it’s sweet heaven.
    PDKTaco, Light1984 and snickers like this.
  6. Feb 3, 2025 at 8:39 AM
    #46
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    It also changes the throttle curve. Sport mode opens the throttle more, earlier into the range of pedal motion.
  7. Feb 3, 2025 at 8:53 AM
    #47
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    I think it's just a result of how much power it takes to push a heavy box down the road, with a fairly inefficient drivetrain (direct symptom of the BOF construction we all rave about). Regardless of engine size, you determine how much power you need with the throttle, and the engine burns a relatively consistent amount of fuel to give you that.
    The main way to improve it is to come up with something like the first years of the second gen Ridgeline: minivan aero plus FWD transaxle drive gets good mileage. It just doesn't look cool, and the drivetrain is not as durable.
  8. Feb 3, 2025 at 9:34 AM
    #48
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    That didn't seem to help the Ridgeline's efficiency much, though. The best year I can find is 21 MPG combined for AWD.
    The Maverick follows this formula and does pretty well, but it isn't really a fair comparison with midsize trucks because it's quite a bit smaller.
  9. Feb 3, 2025 at 9:41 AM
    #49
    Frankmig
    Frankmig Well-Known Member
    2019 4x4 DCSB TRD Sport Tacoma White
    Predator step up bars, Tonneau cover OEM
    I have the same model and getting identical results. On third tank of gas too.
    dleithaus[QUOTED] and Lennyz1 like this.
  10. Feb 3, 2025 at 12:46 PM
    #50
    OldSkoolArcher
    OldSkoolArcher Well-Known Member
    Nick
    PA
    '24 Tacoma OR, '24 Defender 110, '15 WK2
    Can you please explain how you bypassed the auto start/stop? Thanks!
  11. Feb 3, 2025 at 6:06 PM
    #51
    Light1984
    Only way to do it that I've found is either turning on tow/haul or shifting over to "manual" and putting the shift limiter up to S8. Truck will drive as normal since you aren't limiting any gears and the ICE will never shut off. Been driving that way for almost 4k miles on mine so far.
  12. Feb 4, 2025 at 3:02 AM
    #52
    Lennyz1
    Len
    Just curious, what is the reason to do this?
  13. Feb 4, 2025 at 3:58 AM
    #53
    Light1984
    I'm my mind, it'll be less wear and tear on the engine over the life of the vehicle. To my knowledge the oil pump is mechanical while the water pump is electrical. Meaning the coolant will cycle if the engine shuts off, but oil won't. And oil is what cools the turbo. Now I'm sure Toyota knows their stuff more than a shmo on the Internet like me, but it just makes me feel a little better about longevity. I got 310k out of my 2005, so I'm going to try to do the same with this one.
    Lennyz1[QUOTED] likes this.
  14. Feb 4, 2025 at 5:06 AM
    #54
    Lennyz1
    Len
    Toyota has been doing this with their hybrids for nearly 30 years and you do not hear much about engine failures. Shifting through multiple gears in the trans at every stop and loading the trans in 8th with the torque converter possible not locked sounds like it could be adding more wear overall.
    I have owned 5 Toyota hybrid vehicles since 2007. My first met it's demise when my daughter put it into a pole and is was just getting broken in at 165,000 miles. I have 3 in the house hold now and never a issue with drivetrain.
  15. Feb 4, 2025 at 5:08 AM
    #55
    Light1984
    Could you elaborate on this? I'm not following what your describing? All I'm doing is setting the shift limiter to S8 thereby not limiting the gear selection available to the truck. I don't actually shift at all, I let the transmission shift as it wants and just drive normal.
  16. Feb 4, 2025 at 6:00 AM
    #56
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    The turbocharger is water cooled and oil cooled, for what it’s worth. we haven’t used pure oil-cooled turbos for decades in production cars
    gmtech, Light1984[QUOTED] and Lennyz1 like this.
  17. Feb 4, 2025 at 6:10 AM
    #57
    Light1984
    Thank you, I learn something new everyday.
    OpeCity[QUOTED] likes this.
  18. Feb 4, 2025 at 6:39 AM
    #58
    Lennyz1
    Len
    You are manually shifting to S8 once and leaving it there until you park it?
    I have not played with the trans much on this truck (too new), but other Toyota's I have owned it changes the shift points based on the input request from the shifter which is all done electronically. This could have you lugging at low speed and possibly the TC not being fully locked.
    If you cannot deal with the engine cutting off, try using the Tow/Haul. This should also bypass the engine stop.
  19. Feb 4, 2025 at 6:43 AM
    #59
    Light1984
    Yes, I leave it in S8. It shifts identical as far as I can tell up and down from 1 to 8, the ICE just doesn't shut off. I wonder if I can see whether the TC is locked with my scan gauge 2? When should it be locked versus not?
  20. Feb 4, 2025 at 6:48 AM
    #60
    Lennyz1
    Len
    That is a good question. I would do a comparison since you have the capability. That would be great info to have.
    Flori-duh Taco likes this.
