Fuel Mileage with 3" Lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lane Cypert, Apr 25, 2008.
  1. Apr 25, 2008 at 8:02 PM
    Lane Cypert
    Lane Cypert [OP] Well-Known Member
    Lewisville, Texas
    2008 silver prerunner double cab TRD
    I was thinking about getting a 3" inch lift and wanted some feedback on how much this would effect my fuel economy. I know it will go down but was wanting to know how much before pulling the trigger. The lift I am planning on getting is the TOYTEC 3" spacers in the front with the rear add a leaf spring. I was planning on running 17" 285/70 tires, keep my stock tires, or going up one size on my stock 17 inch sport rims. I have always heard that the tire size makes more of a difference on fuel ecomony than the lift itself so was curious from the field. I just wanted some more opinions from some people running similar set ups before taking the plunge.
  2. Apr 25, 2008 at 8:56 PM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
  3. Apr 26, 2008 at 8:53 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I have a 3" lift but haven't put any rims or tires on it yet and last night I got 22mpg. Really 21.7 mpg.
  4. Apr 26, 2008 at 10:26 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    on my truck i have a 3" lift with aal and 1" block in the rear. im running 265/70R17's on it and i average around 17-18mpg. i got a scangauge a week ago and ive ,mamaged to increase my mpg to about 18-19.5 with it. i just ran a 250 mile trip last night and watched my scangauge mpg and managed to get 21.4mpg! not bad at all since my truck is the 6 speed manual.
  5. Apr 26, 2008 at 11:35 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    3" Toytec spacer AAL lift with 285/75 16 tires (32.8" tall). With my scangauge I could tell I was getting consistent 17-18 mpg. After switching the air filter to an AFE Pro Dry I've gotten 20.2-20.3mpg according to the scangauge for the last 2 tanks.
  6. Apr 27, 2008 at 9:43 AM
    Lane Cypert
    Lewisville, Texas
    Thanks for the input. I am glad the fuel mileage loss is minimal on a 3" lift. I think I am going to pull the trigger shortly and buy my TOYTEC lift.
  7. Apr 28, 2008 at 7:47 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    the lift doens't affect you that much, its the tires. i have a 2.5" lift and 32" tires (stocks are 30" or 31", cant remember) My mileage has gone down about 1 mpg but when you factor in the larger tire covering more ground i probably only lost around .5 mpg. on my trip to NC this weekend i got 21.1 mpg on the highway, and thats not compensating for the tires so i probably got closer to 22
  8. Apr 28, 2008 at 7:54 AM
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    Agree with nd, it isn't the lift so much as the tires that affects mileage. Bigger tires = decreased mileage as a general but pretty reliable rule. The lift will increase wind resistance just a tad, but the mileage hit from that will be minimal whereas the tires, depending on what you end up with, can make a significant difference.
  9. Apr 28, 2008 at 11:51 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Don't forget to adjust calculations for larger tires. If you calc mpg based on the odometer or trip meters while running larger tires you will see a drop. However, it may not be accurate. I run 285/75 16's that are 2" larger than stock. My odometer calculations say 17-18 mpg, but my scangauge says 19-20. Right now the odometer reads just over 18mpg while scangauge (and calculations based on the 7% increase in speed due to the tires) read just over 20mpg.
    So figure out how much the tires throw your speedometer and odometer off and adjust your calculations before saying larger tires drop your mpg by X amount.
    Think about it: larger tires = less revolutions for the same distance = lower speed and distance readings.
  10. Apr 28, 2008 at 2:46 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    3" lift, running 285/70/17 BFG MT KM2's - 14.8 mpg
    If I account for the difference in speedo with the lift and tires, that jumps up to a whopping 15.5.
    Lot of stop and go city driving and the 6400 ft elevation probably doesn't help either. For the record, I have never been above 19mpg, even in stock form.
  11. Apr 28, 2008 at 2:51 PM
    piercedtiger
    Jon
    Southern Tier, NY
    I never got over 19 (or rather 18.8ish) myself either until I switched to the AFE Pro Dry filter! Since then the last 3 tanks have been the highest ever over the last 2 years! Last 2 complete fill ups (18gal) have been 20.2-20.3mpg according to the scangauge! :D
  12. Apr 28, 2008 at 4:35 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    I need to get a scangauge as well....as I am sure that will help with a more accurate reading. I'm running the TRD CAI and exhaust as well, with a URD MAF calibrator (I could always tune the maps for better MPG).
  13. Apr 28, 2008 at 4:57 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    With a 1st gen w/3" lift and 33's, I lost maybe 1 mpg.
  14. Apr 28, 2008 at 10:24 PM
    RelentlessFab
    Eric
    Sparks, NV
    since i got my scangauge ive been getting the best gas mileage in my truck ever. its definately gonna pay for itself in no time. i got 21.4 to home, 19.6 back to college. this is on a trip that i used to get between 17.8 and 18.7 mpg with one trip home making 19.1 mpg. so, its made a 1.8-2.3mpg increase, or about 10%. that can be shown as paying 10% less for my gas and @ $3.69 a gallon thats $.37. it'll translate to about $259 a year at my 14,000 miles a year i tend to drive.:D:p
  15. Apr 29, 2008 at 4:26 AM
    Davidgaud
    Davidgaud Member
    second gen with 3 inches lift kit and 33x11,5x18....i was sure to see a bigger difference on the mileage but not that much...maybe 1 or 1.5mpg....no regret !
