fuel mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Remy13, Feb 12, 2015.
  1. Feb 12, 2015 at 5:51 AM
    Remy13
    Remy13 [OP] New Member
    Jeremy
    utah
    07 PreRunner
    Got the truck in florida, now im in utah, it was getting about 20mpg at sea level. Now at altitude its only getting about 15mph. Problems, solutions..........GO!!!!!!!!
  2. Feb 12, 2015 at 5:52 AM
    Pigpen
    Dan
    Northwest Montana
    The computer will adjust, bringing you to a cozy 17.5
  3. Feb 12, 2015 at 5:54 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    Im thinking about possibly driving mine from ma to fl this spring or summer. Howd it do?
  4. Feb 12, 2015 at 10:29 AM
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    colder temps, winter blend gas, constant changes in elevation, less HP due to altitude (heavier throttle foot) will hurt MPG. not much you can do beside go back to FL.
  5. Feb 12, 2015 at 10:44 AM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Lower octane too.
  6. Feb 12, 2015 at 10:48 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    15MPG is all I get under normal conditions, but that's what you get when you treat the gas pedal like an on/off switch.
  7. Feb 12, 2015 at 2:12 PM
    Remy13
    Jeremy
    utah
    07 PreRunner
    It did great on the trip home. Had no problems except the sheet of ice on the interstate outside of dallas. I was wondering if the computer should self adjust or if they are programed. I was getti g 400 miles a tank now barely over 300. Im sure the lack of O2 up here has something to do with it. Any sugestions on getting a lil better mpg would be greatly appriciated.
  8. Feb 12, 2015 at 3:18 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Most likely one big problem is the difference in gas. Every area has different types of winter gas. Also you are in a colder climate and the air is heavier so you will have more drag.
  9. Feb 12, 2015 at 3:18 PM
    savedone
    Gerald
    Texas
    Octane has nothing to do with MPG.
  10. Feb 12, 2015 at 4:21 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    I'm around 17.3 to 17.5 with my 2014 TRD Offroad 4x4 V6
  11. Feb 12, 2015 at 5:46 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    also check your tire pressures, altitude and temperature both affect tire pressure
