Fuel Mileage???
Discussion in '1st Gen. Tacomas (1995-2004)' started by GuardDog, Feb 19, 2016.
  1. May 21, 2016 at 3:03 PM
    #61
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    20%, that's a significant increase. Something else must be going on, you should be able to get better than than 12MPG (assuming 240 miles is empty) My thought is driving behavior.:notsure:
  2. May 21, 2016 at 6:57 PM
    #62
    Bejabbers
    Bejabbers Well-Known Member
    Shane
    2001 Tacoma TRD DoubleCab 4x4
    3"SL 1.5"BL,2.5" exhaust,custom bumpers,Warn 8274,235-85R16's,Flex-a-lite Electric fans, AFE CAI, 18" Magnaflow, High flow Converter, 1.5" BL, Fabtech coilovers, AllPro Expedition leaf packs, Daystar 1.25" extended rear shackles, Billstein 5165 remote res rear shocks, Custom ARB style plate bumper, Singer 275Amp high output alternator, URD MAF sensor calibrator, Innovate MTX-L Wideband O2 sensor, ScanGaugeII, Tundra front brake upgrade, 3" extended braided stainless brake hoses, Cooper Discoverer ATW on Mickey Thompson Classic Baja Lock wheels
    You should check how many gallons it takes to fill the tank up after you clock the 240 miles.
    We have 18 gallon fuel tanks but you never run it completely empty, usually when the fuel gauge is near empty it takes 16 gallons to fill up.
    At 16 gallons your mileage would be 15mpg which still seems low but it is an improvement.
    I get about 17.5mpg mixed city/hwy in my 2001 Doublecab 4x4 automatic with about 300lbs of winch and bumper up front.
    I do use 94 octane premium and have a cold air intake and free flowing exhaust so that may help.
  3. May 22, 2016 at 3:08 AM
    #63
    GuardDog
    GuardDog [OP] Member
    2001 Tacoma 3.4L Auto 4WD
    31" Duratracs, 3" rear lift, Bilstein shocks all around.
    ok well my driving habits are conservative. As for keeping track of how many gallons, when i fill up, it's usually btwn 60-70 litres. (15.85-18.49 gallons). Premium octane is too damn expensive up here. $1.30/litre something along thoses lines. ($4.92/gallon). So I put in 89 octane which is currently sitting at $0.97/litre.
  4. May 22, 2016 at 2:11 PM
    #64
    Hiluxborn
    Hiluxborn Well-Known Member
    Clint
    2002 white tacoma trd
    5 inch tuff country lift, adjustable bilsten 5100's. Toyo MT's on 16' wheels. Magma flow muffler. Viper alarm/auto start. Moog sway bar links,tie rod ends and lower control arm bushings.
    I was getting about ten Mine holds 16
  5. May 22, 2016 at 10:10 PM
    #65
    Bejabbers
    Shane
    Ten mpg! Ouch
    I just went for a 4 hour drive on the hwy @ 100km/h, lots of rolling hills and curves but I watched my Scangauge and tried to take it easy,
    I averaged 20mpg (11.5L/100km)
    I was surprised I could get such decent mileage considering I have a 2.5" lift, 32" tires, heavy winch bumper, and automatic transmission.
    Maybe you need a new O2 or Air Fuel sensor?
    With a Scangauge or Wideband you could see if your truck is running rich.
  6. May 23, 2016 at 4:37 AM
    #66
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    My last tank had a lot of 70-90 km/h driving on it and I got 9.5l/100km
    That's the best I have seen so far in 8000 km of owning this tacoma.
  7. May 23, 2016 at 6:55 AM
    #67
    Bejabbers
    Shane
    That's great mileage! Do you have standard or automatic?
  8. May 23, 2016 at 7:21 AM
    #68
    Northern Taco
    Standard, 4cyl, 2.7l
    Usually I get 10-10.5l/100km 80% 90-100km/h and 20% woods driving at various speeds, some 4wd.
  9. May 23, 2016 at 7:47 AM
    #69
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    I was averaging 18-19/mpg the first few tanks.
    I switched to Mobil-1
    I did the rear diff with RP. That and the May 1 switchover to summer gas/RFG and I am now averaging 19.5 to 20.5/mpg.
    I did a drain and fill with Valvoline synthetic ATF, I will do a flush/filter and switch to RP in the future.
    Worst mileage was on a trip to Austin, CC at 75-85, about 16.5 MPG.
    L4, 2WD.
  10. May 24, 2016 at 5:37 AM
    #70
    lakerman
    lakerman Well-Known Member
    1stgen taco
    Did the tanks get bigger, my 97 only gets 56 litres max?
  11. May 26, 2016 at 4:48 PM
    #71
    GuardDog
    I looked it up. The 2001 Tacoma XtraCab 4x4, 3.4L V6 TRD Off-Road package comes with an 18.5 US Gallon tank (70 Litres). The 2.7L engine also has the 18.5 Gallon tank. The 2.4L engine has the smaller 15.8 Gallon tank (59.8 Litres).
  12. Jun 28, 2016 at 9:47 PM
    #72
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Gas light came on for about 3 miles. Needle was buried.
    2001, Double Cab, Prerunner. 2.7L. AT
    Filled it with 15.7 gallons.
    60% highway (70mph), 40% city driving. AC on 90% of time. Lots of highway grade=eats up MPG
    Got 21.7MPG
  13. Dec 11, 2016 at 7:57 PM
    #73
    1997tacomav6
    Denver
    3.4 v6 supercharged 10.5x31x15 tires with 5 speed, I average consistently 20 miles per gallon, best was 22 mpg, worst was 18.5 mpg using fuelly app
  14. Dec 11, 2016 at 8:05 PM
    #74
    PROseur
    Pussy
    Winter gas killing my mpg :(
    retroboy1989 likes this.
  15. Dec 11, 2016 at 8:43 PM
    #75
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
  16. Dec 12, 2016 at 7:48 AM
    #76
    KGN
    KGN Well-Known Member
    2011 Tacoma 2.7L
    Thats roughly what I get with my 2001 2.7 4x4. I have done about 570 kms before I filled up, could have got more but the gas stations are far apart around here. Pretty happy with it, and glad I got the 2.7, except when I am driving up hills, then I wish for the 3.4.
    Truck is all stock,15 tires(I know, no fun) This is in the warmer months, I will hit the odometer and check again this winter.
  17. Dec 12, 2016 at 7:08 PM
    #77
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Instead of counting gallons, I reset my ODO once the gas line comes on (When it is bright and clearly on, not just flashing/dim). Then I put in 10 gallons and check the ODO when the light comes back on. I was getting 180 miles to 10 gal (18 mpg) mix city highway and 21mpg highway for years, but 6 months ago it dropped to 13-14 :(. I did have a 50 gal diesel fuel auxiliary in there for while, and around the time I took that out I did upgrade to the 265/75 duratracs from Michelin M/S (P-rating) but I don't think those would have caused such a big drop. I have have been getting a reoccurring P0420 CEL during the same time the mileage dropped, and my truck smells like an ATV. Heavy emissions smell.
    I want to do plugs and wires, pvc valve and figure out what needs do be done for the code. Either sensor, bat cat or what have you. I'm not sure
