Fuel mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Moose66, Feb 14, 2017.
  1. Feb 15, 2017 at 8:19 AM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    2 miles commute, I see about 13 MPG on each tank. :(
    Fresh oil, air filter, 40 PSI in new K02 265/75R16 tires (no lift nor accesories), MAF cleaned...I'm due for 30K spark plugs, hoping that helps some. If not, I'll be looking into fresh driveline fluids.
    I expect to atleast flirt with the EPA city estimate of 17...13 just isn't close enough at 23%-24% under (and this is summer and winter ((if we get winter gas here)) gas).
  2. Feb 15, 2017 at 9:52 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    15mpg city, stock V6
  3. Feb 15, 2017 at 10:14 AM
    acarboneau10
    acarboneau10 Active Member
    Andrew
    2014 TRD Off Road Double Cab Black
    None yet
    18.3-18.8... I drive 104 miles per day round trip, so nearly all highway. Average speed of 60 MPH I would say. The truck is all stock.
  4. Feb 15, 2017 at 10:25 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I got 19.7 on last tank. Running Cooper ST MAXX 265/75/16. Baja sits level. It was warm here last week and I think that caused my mileage to jump from previous colder weeks. All hwy at 65 - 75.
  5. Feb 15, 2017 at 9:04 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    2 mile commute, no wonder, it's not even close to warmed up. New Plugs and fluids won't change that.
    nv529 likes this.
  6. Feb 15, 2017 at 9:31 PM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Yeah, it's a large part of the problem.
    That said, I'd still expect 15ish (based on experiences with the same commute yet in several other DDs and their yield).
    Add to that a recent trip to Albuquerque that netted me 16 MPG highway, in total, and I'm thinking there's more to the story.
  7. Feb 16, 2017 at 1:17 AM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    honestly I have no idea and probably do not want to know, but I could have bought a prius if I was concerned about getting good mileage.
  8. Feb 16, 2017 at 4:47 AM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Nobody said they wanted "good" mileage out of their 4.0...just close to the rated MPG of the truck, but thanks for the helpful post #enlightened
  9. Feb 16, 2017 at 5:21 AM
    TacomaMike37
    13' DCLB MGM
    16 is pretty average man. Not great , but not horrible and nothing is wrong with your truck. I get maybe 17 on highway. I dont drive like a grandma either like the other members humblebragging about their 18-20mpg.
    You want good gas mileage then you have to go 50-55mph on the highway. Im not comfortable with that as the average speed is 65+ around my parts.
  10. Feb 16, 2017 at 5:42 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Are you compensating for the 285's in that equation? Somewhere on thi forum is a chart for tire size mileage compensation. With that said I currently get 16 at best on 265/70/17 for my regular commute. Putting 285's on today expecting another mpg hit. When the truck was stock I got 18 mpg.
  11. Feb 16, 2017 at 6:04 AM
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    This is your main culprit. The longer you let the truck idle from cold, longer the EFI system will stay in open-loop causing it to run pig rich and burn a ton of fuel while idling.
  12. Feb 16, 2017 at 6:38 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Really good point. Earlier in the thread I mentioned idle burn of 0.5 gal/hr but that is for a warm engine. Cold it is more like 1.5 gal/hr.
    Let's do some math because math is fun!
    Cold idle is 1.5 gal/hr so a ten minute warm up is taking 0.25 gals. Assume you get 16 highway with your configuration then a 24 mile commute would burn 1.5 gals. Add in the idle warm up burn and you've got 24 miles / 1.75 gals which is 13.7 mpg. Warmup knocked off almost 2.5 mpg. Shorter commute effect would be even worse.
    Moose66[OP] and nv529[QUOTED] like this.
  13. Feb 16, 2017 at 6:38 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  14. Feb 16, 2017 at 6:52 AM
    nv529
    Nick
    Lets not forget stock 265/65R17 trd-sport tires travel 1.065 miles (659.89revs/mile) for every 1 mile on 285/70R17 (616.6 revs/mile). so 250 odometer miles is actually 266.25 traveled miles with 285's.
    Juforrest and DVexile[QUOTED] like this.
  15. Feb 16, 2017 at 10:40 PM
    #35
    natas1321
    natas
    san antonio
    anytime
  16. Feb 17, 2017 at 12:06 AM
    #36
    Wyoboypt
    Wyoboypt Well-Known Member
    Wyoming
    10 sr5 trd sport DCLB
    235/85 r16. I get 16-19 depending on how I drive. Also only use ethanol free fuel. That helps. ALOT.
  17. Feb 17, 2017 at 6:46 AM
    #37
    Colt4587
    Colt4587 Well-Known Member
    Colt
    2015 Red Tacoma TRD Sport
    I was getting 17-19 bone stock. Then upgraded tires to 265/70/R17 Duratracs, and now I'm getting 13-14. Could also be the winter gas too.
    I'll see how it does in the springtime, now that it is starting to warm up here.
  18. Feb 17, 2017 at 6:54 AM
    #38
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I don't personally like duratracs, but they shouldn't drag your mileage down that bad. On my first Tacoma they dropped my mileage by about 1 mpg on a 265/75-16, one size over. Was getting about 18 and dropped to 17. That was an AC off-road 6 speed manual.
    On my current Tacoma DCLB auto sport, I was getting 21ish highway. With my falkens it dropped to an average of 18.5-19, same 265/75-16 size. On occasion I'll get 21 highway. Perhaps less ethanol at some station.
  19. Feb 17, 2017 at 6:55 AM
    #39
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    15-16 so far this winter, but that's with some idling in the morning. Usually get 18-19 in the summer.
  20. Feb 17, 2017 at 6:56 AM
    #40
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    About 18 was best i ever got, and thats with 245 dunflaps on it.
