fuel pressure spec
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glamis, Jul 16, 2017.
  1. Jul 16, 2017 at 7:40 AM
    Glamis
    Glamis [OP] date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    I'm looking to test my fuel pressure on my 2008 4.0 auto 153,000. I feel that some power has been lost on the freeway. I'm getting some downshifting on freeway rise. The truck always held the gear the this freeway. nothing has change with the road or my trucks tires started about 2 months back. hubs new and spin free.
    im looking for the test port and the spec on fuel pressure
    thanks...
  2. Jul 16, 2017 at 7:45 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    There is no test port. Here's what Toyota says
    • Install SST and the fuel tube connector onto the vehicle. SST 09268-41048 (90467-13001, 95336-08070, 09268-41500), 09268-45014 (09268-41200, 09268-41220, 09268-41250)
    • Measure the fuel pressure. Standard: 281 to 287 kPa (2.87 to 2.93 kgf/cm2, 40.8 to 41.7 psi)
    • Check that the fuel pressure does not change for 5 minutes. Standard: 147 kPa (1.5 kgf/cm2, 21 psi)
    BeeRadd likes this.
  3. Jul 16, 2017 at 8:17 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Could be lots of things, from a lazy oxygen sensor to a cat starting to get plugged up, could be transmission related as well. Start with the basics, spark plugs, throttle body cleaning, MAF cleaning air filter.
    RyanV1 likes this.
  4. Jul 16, 2017 at 11:15 AM
    Glamis
    spark plugs, throttle body cleaning, MAF cleaning air filter are good to go. Trans flushed at dealer every 60k
  5. Jul 16, 2017 at 11:20 AM
    Glamis
    lot of work for a simple test. my S-10 just had a shredder inline :/
  6. Jul 16, 2017 at 12:43 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Not really that much work.
