Fuel pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by __TT__, May 3, 2025.
  1. May 3, 2025 at 3:44 PM
    __TT__
    __TT__ [OP] Well-Known Member
    06 sr5
    This seem like normal fuel pressure?
    Back story. 06 4.0 300k
    Driving normal and just stopped on freeway. Sounded like no fuel. Can't hear or feel pump when I touch it. Bypassed resistor and this is what I get out of it.
    https://youtube.com/shorts/JyoiGhNO2TI?si=axrD6i6bKSTey8tL
    It's just dribbling out
  2. May 3, 2025 at 4:12 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Native video uploading isn't supported, you have to post it to a video sharing site like youtube and then post the link here.
  3. May 3, 2025 at 4:21 PM
    __TT__
    06 sr5
    Thank you
  4. May 3, 2025 at 4:45 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Looks like plenty fuel coming out but that doesn't tell you if it can make pressure or not.
  5. May 3, 2025 at 4:45 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If that is the feed line, you have a problem. That should be shooting out of there forcefully.
  6. May 3, 2025 at 4:58 PM
    __TT__
    06 sr5
    Starts and runs with ether. Ordering a pump
    Torspd likes this.
  7. May 3, 2025 at 5:38 PM
    Bishop84
    Bishop84 Well-Known Member
    We're starting to see corrosion cause issues with the harness and connector back there.
    Also we're seeing fuel level sender issues. Are 100% sure there's fuel in it? Can you splash in a jerry can?
    Dm93 likes this.
  8. May 3, 2025 at 6:10 PM
    __TT__
    06 sr5
    It's at 1/8. I'll put in another gal tomorrow to make sure its not the sender.
    Ya know about a week ago I noticed my low fuel light coming on sooner than normal now that I'm thinking about it.
    Bishop84 likes this.
  9. May 4, 2025 at 7:56 AM
    __TT__
    06 sr5
    Yep out of gas.
    So im still gonna need to get in there to clean or replace the sender yeah.
    Bishop84[QUOTED] likes this.
  10. May 4, 2025 at 8:06 AM
    Bishop84
    Lots of professionals get caught up with this, including myself. Glad it was that easy.
    HondaGM and winkel like this.
  11. May 4, 2025 at 8:26 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The last 3 cars we thought needed fuel pumps ended up having holes drilled in the tanks :oops:
    Bishop84[QUOTED], HondaGM and Torspd like this.
  12. May 4, 2025 at 8:30 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I make a concerted effort to not run my fuel that low. Many drivers think nothing of running the tank down to empty which wasn't much of an issue with mechanical fuel pump but in today's vehicles it's not doing the system any favors since the pump are cooled and lubricated by the fuel in the tank. Running it down to the point where the engine is starving for fuel is aging the fuel pump prematurely.
  13. May 4, 2025 at 9:08 AM
    __TT__
    06 sr5
    Where are you seeing the corrosion?
    HondaGM likes this.
  14. May 4, 2025 at 11:36 AM
    Bishop84
    Harness from frame to sending unit. It's worth opening the loom and making a good visual check when you're in there.
    Torspd, b_r_o, Jimmyh and 1 other person like this.
