Fuel Problem.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by No Shoes Nation, Apr 4, 2020.
  1. Apr 4, 2020 at 5:32 PM
    No Shoes Nation
    No Shoes Nation [OP] Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Problem is you need it, to make the dang truck run.
    Here's my problem.
    Truck would start and die, start and die, I know its out of gas. I put approx 2 gallons ish in. Drive to gas station. Can only squeeze 7 more gallons in. My math makes that 9ish gallons, WHY?
    Gas gauge reading correct is another issue.
  2. Apr 4, 2020 at 7:19 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Is the tank full? This sounds like an issue with your fuel pump. Loses pressure and can't pump fuel past a certain point.
  3. Apr 4, 2020 at 7:28 PM
    No Shoes Nation
    Pretty sure it’s not pump problem after adding a few gallons ran fine
  4. Apr 4, 2020 at 7:42 PM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    Hmm... The amount of fuel in the tank wouldn't matter to healthy pump as long as there is some.. Interesting.
