Fuel Pump Change
Discussion in '1st Gen. Tacomas (1995-2004)' started by Layzboy, Sep 13, 2017.
  1. Sep 13, 2017 at 1:25 PM
    Layzboy
    Layzboy [OP] Well-Known Member
    Rob
    Glendale,AZ
    99 Rerunner TRD Off Road Sunfire Red Pearl
    Just gettin started
    I Have a New OEM Fuel Pump. Bed Is Removed. Anything I need to know before I Do the Swap? Seems pretty easy and straight foward. Any Tips Or any Snags I may run into?
  2. Sep 13, 2017 at 1:27 PM
    tcjacado
    tcjacado Well-Known Member
    @Speed Freek You have done a couple of these Right?
    I believe you just need to empty the tank as much as possible and no smoking. Lol. I know great advice captain obvious, but who knows, you could be a Florida native for all I know. Good luck.
    RedRed likes this.
  3. Sep 13, 2017 at 6:53 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    No 1st Time to do this.
    tcjacado likes this.
  4. Sep 13, 2017 at 6:55 PM
    tcjacado
    I figured it was your first time the gentleman i tagged is a toyota master mechanic. It also helps to have a extra set of hands if you got a friend that can help you drop the tank down. Other than that its pretty straight forward also disconnect negative vable on the battery.
    Try this
    https://www.google.com/url?sa=t&sou...ghjMAs&usg=AFQjCNFFnvgni7Oo4n3-LHIp-mn7GqVWdQ
  5. Sep 13, 2017 at 7:31 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Very Cool. I already have the Bed removed.
    tcjacado[QUOTED] likes this.
  6. Sep 13, 2017 at 7:35 PM
    tcjacado
    There are several other threads in other forums that have this info too. Just type in "how to replace a fuel pump in a tacoma" into google
    Happy reading
  7. Sep 13, 2017 at 8:01 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Double cab, easier to change when drop/tilting the tank.
    Xcab/reg cab, loosen bolt to bed, tilt and raised bed and you'll be fine
    Hydraulic table will be your best friend of you're handling it yourself, if you decide to drop the tank
    No need to drain tank. Make sure you're working in a well ventilated area. NO GUARANTEE IF YOU SMOKE, YOU'LL BE A STATISTIC.
  8. Sep 13, 2017 at 8:34 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Battery is out. Bed is Off. Truck is Outside. Don't Smoke...Cigarettes! Just have to drain some fuel and I believe I'm Good. Thank You for the input gentleman.
    jammer and tcjacado like this.
  9. Sep 14, 2017 at 2:22 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Your in AZ you should be fine .
    You should be able to break all the lines loose although spraying them can`t hurt .
  10. Sep 14, 2017 at 2:28 AM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    I'm doing this as well. Was going to lift the bed up. Went to loosen the bed bolts and now they just spin. Whatever nut inside the crossmember must have broke. Looks like I'll be removing the tank.
  11. Sep 14, 2017 at 10:28 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    In PA there could also be rust problems with the small screws fastening the pump/sender assembly to the tank. Sometimes the rubber gasket can get deformed if any rust has crept under it and a new filter should go on the pump pick up.The replacement Denso brand pump filters are much finer than the factory installed "strainer".
    I like dropping the tank anyway, it's no big deal and that way it's easy to touch up rust spots on the tank and inspect the insides good for rust and dirt.
    Don't forget about static electricity, keep that tank grounded.
  12. Sep 14, 2017 at 11:37 AM
    Glamisman
    Glamisman Well-Known Member
    there should be a evap box on the front portion of the tank... these hoses and electric valve can be an evap code "issue". If they look fine and are still soft and rubbery you should be good. If they are hard and look like cracking you could attemp to replace them. The last thing I would want to happen is you get her back together and it pops an evap code and you have to do it all over again or you start to mess with them and something goes wrong.
  13. Sep 14, 2017 at 12:08 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I always have a New fuel pump bracket I have yet to get one apart that did not break.
  14. Sep 15, 2017 at 12:01 AM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Have Pump out. I am going to replace small fuel hose it connects to.
    Dalandser likes this.
