fuel pump issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by innerrage, Jul 10, 2014.
  1. Jul 10, 2014 at 2:24 PM
    innerrage
    innerrage [OP] Member
    brian
    ct/fl
    96 tacoma 4x4 2.7 flowmaster kn bilstien etc
    2inc bilstien suspension kn air induction flowmaster exchaust
    Hi I have a 1996 Toyota Tacoma 2.7 4x4 since January I have replaced the fuel pump 3 times and now going on my 4th and replaced the fuel filter and fuel pump relay.The last pump was a Bosch.should I have the gas tank boiled and cleaned and put a whole new fuel pump assembly and pump in again.
  2. Jul 10, 2014 at 2:27 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Not sure of your situation-but-have you checked the RETURN LINES?
    my son had a similar problem in his CAR-the return lines were clogged.-Just a thought!
  3. Jul 10, 2014 at 4:13 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Can you visibly see gunk in your filter when you replace?
  4. Jul 10, 2014 at 5:10 PM
    innerrage
    brian
    ct/fl
    will have the mechanic check the fuel and will have him check the filter screen thank you
  5. Jul 16, 2014 at 7:39 AM
    innerrage
    brian
    ct/fl
    ordering a new pump assembly they think mine might have a short somewhere,just sucks
  6. Jul 16, 2014 at 7:44 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    The question is of course what has caused the multiple failures. I would want to see how the most recent pump looked when it was removed. May be time for a new tank. I wouldn't waste my time cleaning it. Once the internal protective coating is damaged, it will just continue to rust.
  7. Jul 29, 2014 at 6:07 AM
    innerrage
    brian
    ct/fl
    the fuel tank is spotless,the fuel pump is a bosch bought on ebay 2months ago and it has a 1 year warranty and the place in Miami said its my mechanics fault it burned out.dont no who to trust anymore.hope its something minor
  8. Jul 30, 2014 at 3:35 AM
    innerrage
    brian
    ct/fl
    yesterday mechanic checked fuel pump and it worked so now its checking voltage to pump assembly and all the fuel pump wireing replaced the relay a month ago.
