Fuel pump keeps breaking down
Discussion in '1st Gen. Tacomas (1995-2004)' started by Benfatto, Sep 21, 2017.
  1. Sep 22, 2017 at 7:37 AM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    Excessive water in the fuel could be causing the pump to rust as well as the issues posted in the other thread. Is the truck in Panama now is that where you are headed to?
    Dalandser likes this.
  2. Sep 22, 2017 at 8:49 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Sounded like he lives down there full time.
  3. Sep 22, 2017 at 8:49 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    If the fuel filter needs to be changed regularly that doesn't say good things about the quality of the fuel. Since the pump runs before the filter it doesn't get any benefit from it. Inspecting the failed pump might tell you more.
    mechanicjon likes this.
  4. Sep 22, 2017 at 8:52 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Where did it mention having to replace the filter more than once? I'm pretty sure I only read about a clogged screen before he fixed up his gas tank and that comes before the pump.
    I agree with inspecting the pump though. If you dissect it there could be some new clues.
  5. Sep 22, 2017 at 8:59 AM
    510tacoguy
    510tacoguy Well-Known Member
    Eduardo
    2004 4 door tacoma
    Body lift suspension lift
    Might be the gas Like stated above, do you get gas at the same place or do you change it around ?
  6. Sep 22, 2017 at 11:21 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Fuel filter gets changed regularly bottom line first post
  7. Sep 22, 2017 at 11:24 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I see. I had read through the whole saga that was linked. Regularly = excessively though?
  8. Sep 22, 2017 at 5:11 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I change mine every spring not so much for the filter being restricted but so I can get it off
    These are supposed to be 100,000 mile plus filters
  9. Sep 22, 2017 at 5:33 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Excessive water in fuel would cause huge drivability issues with the engine. It would run terribly.
  10. Sep 22, 2017 at 6:48 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    He did day mileage was way down.
  11. Sep 22, 2017 at 7:01 PM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Water in fuel -- bucking lurching engine. It creates a misfire. It's a different symptom than low fuel mileage.
  12. Sep 23, 2017 at 1:57 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I think dirt would be more of a issue then water.
    OP`s comment was pumps keep burning up
    Does that mean the impeller is worn to the point it will no longer pump
    The bearings are so bad they seize ??
    Being a DC motor under voltage will just slow the rpm down which happens in 30 year old vehicles like my eighties Toyota`s
  13. Sep 23, 2017 at 2:04 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    The $398 question is what brand of pump are you buying?
  14. Sep 23, 2017 at 8:07 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    He said Denso. Might have been in the other thread. But is it true Denso?:notsure:
  15. Sep 23, 2017 at 8:59 AM
    #35
    Benfatto
    Benfatto [OP] Well-Known Member
    Panama
    Tacoma '96 2.4
    • The quality of fuel in Panama is definitely a concern so I top up the tank any time I'm in the city and avoid the countryside pumps. But it does not explain this level of pump failure, nor the engine codes or low mileage.
    • I change the filter regularly because of fuel quality, I just assume that it might help the pump, however it still breaks down.
    • Haven't done an autopsy on my late fuel pump but will do so now.
  16. Sep 23, 2017 at 10:09 AM
    #36
    Wyoming09
    New Tripoli Pa
    Super Springs
    When your replacing the pumps just what do the socks look like ??
    The filter changes are keeping dirt out of the injectors
  17. Sep 23, 2017 at 10:40 AM
    #37
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The Denso "kits" contain everything. Sock, connector hose, clamps, clamp holders and grommets. Wonder if the OP is getting counterfeit goods.
    The replacement Denso sock is every bit as fine as the inline filter as opposed to the factory "screen" sock.
    Denso kit.
    OE pump at around 175K. Was working like a champ, replaced as PM.
    Nothing to wear in the pump itself.
    However commutator/brushes are another story.
    But still, in the early days folks were boosting voltage to OE pumps for supercharger applications before the availability of larger volume units with no ill effects.
    Dalandser and mechanicjon like this.
  18. Sep 23, 2017 at 4:05 PM
    #38
    Wyoming09
    New Tripoli Pa
    Super Springs
    Your wrong about nothing to wear .
    Your pump was in good working condition
    The more scored things become the flow and pressure decline
    that is why I was thinking dirt is a problem.
    Can`t wait to see the OP`s pump
  19. Sep 23, 2017 at 4:20 PM
    #39
    Dirty Pool
    99 XCAB V6 MT TRD
    There is no contact between the impeller and the housing, it would take some serious contamination to mess it up and it would have to get passed the sock.
    OP said he is using the Denso Kit, like I said the Denso kit comes with an upgraded filter sock, every bit as fine as the paper post pump filter. If this is a dirt issue it should be very obvious to the OP and seen on the sock.
  20. Sep 24, 2017 at 3:12 AM
    #40
    Wyoming09
    New Tripoli Pa
    Super Springs
    It is to bad I don`t have pictures to post to prove my point .
    Such is life .
    Curious to see just how this plays out
