Fuel pump open circuit relay question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dashdanger, Jul 24, 2022.
  1. Jul 24, 2022 at 2:23 PM
    Dashdanger
    Dashdanger [OP] Active Member
    99 tacoma 3.4 ext cab 4x4
    Shorted wrong terminals on fuel pump open circuit relay blew efi fuse replaced fuse good wont start cranks fine
  2. Jul 24, 2022 at 3:24 PM
    1997tacomav6
    Denver
    Replace relay under dash too ?
  3. Jul 24, 2022 at 5:11 PM
    Dashdanger
    I didnt replace the fuel pump open circuit relay since it worked fine when I pulled it. I was trying to get the fuel pump to run to empty the tank but jumped the wrong terminals blew the efi fuse. Replaced the fuse and swapped the relays under the hood.
  4. Jul 24, 2022 at 5:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you jumped the relay wrong. You could have sent 12v directly to the ECM.
    Sometimes this cause problems, like ECM problems.
    I’d pull that relay and see if you have 2 powers.
    If so, make sure the relay is good. Then test the pump for power.
    Or be REALLY REALLY CAREFUL and jump the relay again. And HOPE the pump doesn’t run.
    If it does, you’re relay isn’t getting commanded to turn on by the ECM. Or the wire from the ECM is bad.
    Do you know what pins to jump now? If not, I may be able to dig up a diagram.
    @caribe makaira might have diagrams for a 99 Tacoma.
  5. Jul 24, 2022 at 5:50 PM
    caribe makaira
    Caribbean, Puerto Rico
    Nope...:playball:
  6. Jul 24, 2022 at 5:56 PM
    TnShooter
    Deogee
    STOCK
    Thanks for looking.
    1999 diagrams are hard to find. 2001 are all over. But when it comes to critical wiring, I like to use the year specific.
    Thanks again:thumbsup:
    Bivouac likes this.
  7. Jul 25, 2022 at 2:21 AM
    Dashdanger
    I dont know which pins to jump. Which is why I shorted the dang thing in the first place. Someone suggested it and I was an idiot. It sparked when i touched it to the terminal and i heard a small pop i thought from under the dash/firewall area. The efi fuse had blown, replaced it. It hasn't blown since. I've disconnected the battery neg for more then 15 minutes. Swapped relays and checked all fuses.
  8. Jul 25, 2022 at 2:37 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Here is the engine control wiring diagram (includes fuel pump) for a 1999 5VZ-FE (let me know if I have the wrong engine).
    TnShooter likes this.
  9. Jul 25, 2022 at 2:44 AM
    Dashdanger
    Engine 3.4 6cyl
  10. Jul 25, 2022 at 2:57 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I do have the correct engine. :thumbsup:
  11. Jul 25, 2022 at 3:06 AM
    Dashdanger
    Now if I only knew how to read a diagram
    super_white likes this.
  12. Jul 25, 2022 at 9:36 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Thank You Sir!!
  13. Jul 25, 2022 at 9:39 AM
    Bivouac
    Do you recall just what pins you jumped that caused your mishap ?
    The pin numbers are on the schematic .
  14. Jul 25, 2022 at 10:00 AM
    TnShooter
    Deogee
    STOCK
    There are also schematics for the relay as well. It’s usually included with the fuse box diagram in the wiring manual.
    Typically, the smaller legs of the relay are control and the larger are feed.
  15. Jul 25, 2022 at 10:08 AM
    Dashdanger
    Well when holding the plug there is one side flat and the other side is indented because there are two terminals on each side and only one in the middle. So with the indention facing up I touched the middle one (only one hot) to the upper lefthand one I do believe.
  16. Jul 25, 2022 at 12:01 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    You are welcome
  17. Jul 25, 2022 at 12:28 PM
    Dashdanger
    Ok I'm new on here and not real savvy with internet etiquette so if I've missed something or come across as offensive I do apologize. I greatly appreciate any and all input and resources everyone has offered. Thank you. I'm fairly mechanically inclined so I don't know why I cant seem to get familiar with reading electrical diagrams.
  18. Jul 25, 2022 at 12:34 PM
    Dashdanger
    Ok I looked at the diagram again and I know I jumped the #4 pin to i think it was the #3 pin that caused the problem. Honestly I jumped #4 and started on the right side touching each one listening for the pump to come on. Nothing happened with any of them until I touched #4 and #3 (I think #3) and that's what blew the fuse.
  19. Jul 25, 2022 at 8:38 PM
    Dashdanger
    So is there anything else it may be since the efi fuse isnt blowing and the relays are all good? ECM?
  20. Jul 26, 2022 at 12:08 AM
    ArizonaBrian
    ArizonaBrian Well-Known Member
    Did you verify operation of the fuel pump as TNshooter mentioned? That would be my first step then start working backwards off the wiring diagram to find out if you're missing power or ground somewhere. Get a test light or volt meter and check for signal from the ECM at the circuit opening relay or directly at the ECM.
