Fuel pump or sensor? Need advice.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlackBeard556, Jul 9, 2019.
  1. Jul 9, 2019 at 5:08 PM
    BlackBeard556
    BlackBeard556 [OP] Active Member
    Brian
    2005 White Tacoma TRD
    Bone stock....at the moment
    05 Tacoma TRD. 4.0 never had any issues Today I was sitting at a friend's on an incline talking for about 10 minutes. Notice the truck revving up and down. Cut my convo short, jumped in and took of . Ran a little rough about 100 yards and cleared up. Stopped at the store a few miles away, got it fired right up and ran great for several miles. I could tell something was off but ran goo . All of the sudden a sudden jolt and die . Coasted off the roa . Tried to restart and it'll fire up and immediately di . Wait a few seconds and it'll do the same thing. Am I looking at a fuel pump or sensor issue? Any ideas?
  2. Jul 9, 2019 at 5:16 PM
    BlackBeard556
    Brian
    Check engine light has been on for years. Haven't gotten a scanner hooked up yet. It will not run at all
    beertimecontinuum likes this.
  3. Jul 9, 2019 at 5:22 PM
    Muddinfun
    Muddinfun Well-Known Member
    Where was the temp gauge when it died?
    whatstcp likes this.
  4. Jul 9, 2019 at 5:51 PM
    KickAss
    KickAss Well-Known Member
    Chuck
    Florida
    2015 Limited 4x4 DCLB
    Big body sittin on chrome
    good luck dude,,,, :popcorn:
    Torspd likes this.
  5. Jul 9, 2019 at 5:56 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Let’s start simple. How much gas do you have in the tank?
    If below 1/4 tank, go put 2-3 gallons in and try again. Seen it happen a few times where people’s gauges were off and they simply ran out of gas.
    Don’t fill the tank up all the way though, in case you do need to replace the fuel pump.
    BassAckwards, ColoradoTJ and whatstcp like this.
  6. Jul 9, 2019 at 8:17 PM
    BlackBeard556
    Brian
    Temp was in normal range with no issue there.
    Just a quick backstory, Dad bought the truck new in 05. Hit a deer between ‘12&’15. Something happened during the wreck and motor started knocking on the way home from the body shop. Motor was replaced with a newer one but check engine light has been on since. I bought the truck a few years ago from my Dad. Never given the light much attention because “it’s been on for years”. Definitely going to have it read though.
    Planning to start there in the morning. It acts like it is out of gas but is showing just over a 1/4 tank. Never had an issue with the fuel gauge but today could’ve been the day.
    whatstcp[QUOTED] likes this.
  7. Jul 9, 2019 at 8:35 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Engine Light shouldn't be ignored. It could have indicated a small problem which over time, manifested itself it dying on the road.
    First thing l thought of was fuel issue. Or something else caused from a fuel issue. But the code reader is your best bet to get the answers you really need to get rid of that Check Engine Light.
    Good luck :fingerscrossed: Keep us posted.
  8. Jul 10, 2019 at 2:06 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’d be my guess then. Hopefully that’s all it is. Good luck
  9. Jul 10, 2019 at 5:10 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Not related to your problem but you might want to run the numbers on the “new” engine.
    When I saw you had an ‘05, thoughts immediately turn to head gasket issues. However you said the engine has been replaced so hopefully you have an ‘07 or later.
    Hope it’s nothing major :cheers:
    LOLLY likes this.
  10. Jul 10, 2019 at 5:15 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I would also recommend start with cleaning the MAF sensor. I hope you didn't neglect routine maintenance (oil/filters/plugs) like you did with the CEL.
    Rick's 2012, PzTank and John Wick like this.
  11. Jul 10, 2019 at 2:26 PM
    BlackBeard556
    Brian
    MAF sensor is the culprit. Thanks guy .
  12. Jul 10, 2019 at 2:33 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Dirty maf? you running an oiled filter?
  13. Jul 10, 2019 at 3:31 PM
    BlackBeard556
    Brian
    I am not running an oiled filter. All I had time to do today before work was pull the code. It'll be the weekend before I can dig into it.
  14. Jul 10, 2019 at 3:43 PM
    BassAckwards
    If youre able to post what code you pulled, we might be able to help you narrow down the issue
    Sugar Silva likes this.
  15. Jul 10, 2019 at 8:22 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Please change the title of this thread. I clicked assuming you needed real help, not just advice (like you were stuck somewhere or some other more dire situation).
  16. Jul 10, 2019 at 9:11 PM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    I thought the same thing!!!
    Crodell6 likes this.
  17. Jul 10, 2019 at 9:17 PM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    Title changed.
    PzTank, Rick's 2012 and stickyTaco like this.
  18. Jul 22, 2019 at 1:54 PM
    BlackBeard556
    Brian
    Ok fellas, here's an update. I've been working so just getting back to fill you in. New MAF was installed after a buddy hooked his scanner up. I honestly dont know the code. Just took his word. MAF did not fix the issue. Considering it's an 05 and the circumstances of the original story, I figured I may as well replace the fuel pump since it's never been done and seemed like a fuel issue. New fuel pump arrived and installed today, still no chang . Truck is obviously getting fire and fuel because it will at just crank. It'll even rev up if you hold the throttle i . But it'll rev up and immediately drop off and die. I honestly don't know what I'm missing her . But, I ran across an old buddy that worked as a Toyota tech and he's coming by Friday evening to take a look with me. All I know is I miss my truck and I want it back.
    PzTank likes this.
  19. Jul 22, 2019 at 1:55 PM
    eon_blue
    Azusa, CA
    See if you can get your buddy to give you the code, hard to know what to suggest without knowing what it is.
    Since he immediately went to the MAF sensor and based on your symptoms, I want to say that maybe you have a big vacuum leak in the engine bay somewhere after the MAF sensor. Check all your vacuum lines to make sure none of them are disconnected or broken. Easy place to start anyway while you try and get the code
  20. Jul 22, 2019 at 1:57 PM
    BlackBeard556
    Brian
    Just to clarify, no, this truck has been serviced every 6500 miles since 2005, yes, I ignored the CEL just because I was used to it being on. But I've never ignored a service.
