Fuel Pump Problem?
Discussion in 'Toyota Trucks & SUVs' started by rawdog, Jan 16, 2010.
  1. Jan 16, 2010 at 3:45 PM
    rawdog
    rawdog [OP] Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    I think my fuel pump is gone, what should i check to be sure before i dig into it?
  2. Jan 16, 2010 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Wanna give any vehicle info?
  3. Jan 16, 2010 at 5:56 PM
    vicstacoma
    vicstacoma Well-Known Member
    Victor
    Santa Maria, CA
    2000 Sr5 4x4
    Air raid cold air intake, procomp 7089 16x8 wheels, bf goodrich all terrain ko 265/75r16. Toytec 3" lift kit. Power slot rotors with posiquiet ceramics pads. Diff breather mod. LR Upper Control Arms.
    what checks have you done to it that makes u think it's the fuel pump?? Does it crank, but won't start??? Have you checked for spark??? Fuel pressure???..
  4. Jan 16, 2010 at 6:03 PM
    rawdog
    Kelowna B.C.
    1990 toyota pickup
    mm
    well it was going good, today i had a little hesitation early in the morning, after work i went to start my truck, it started and ran for about 6 seconds then started hesitating then died.. started again lasted 4 seconds.. and again slowly til it wouldnt run at all.
    it cranks fine it just isnt firing.
  5. Jan 20, 2010 at 2:00 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    You have a carb.
    Are you getting fuel when you pump the accelerator?
    Look in the carb. when you take the A/C off.
  6. Jan 20, 2010 at 2:29 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    no carb in the 3.0 V6
  7. Jan 20, 2010 at 2:43 AM
    indbobber
    indbobber Member
    Rudy
    Pa
    09 reg cab 4cyl 5speed 4WD
    intermittent wipers,hood protector,fog lights, wheel skins
    sounds like a fuel filter change is due
  8. Jan 20, 2010 at 6:23 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    Guess I figured a '90 truck would have a carb.
    Oh well.... shot my idea down.
    Thanks for the info. All my Toyota pickups had carbs until my '01.
    (I forgot my '89 Land Cruiser has FI.)
    Sometimes carbs are easy for trouble-shooting and sometimes not.
  9. Jan 20, 2010 at 9:32 AM
    rawdog
    Kelowna B.C.
    there is a new fuel filter..
    ya, no carb.
    when i took the bed off the get to the fuel pump. the bloody gas tank doesnt have a spot of rust on it, but wouldnt you know that the fuel line going to the tank is rusted to f. i was knocking a bit of the rust off so it didnt fall into the tank when i took the fuel pump housing out, while doing this the fuel line actually started spraying fuel everywhere. so now its covered in cat litter to soak up the gas so i can fix this hole.. fun times.
    anyways.. its already all apart with the part ordered. i'll let you know if it actually was the fuel pump not.
