Fuel pump question
Discussion in 'Performance and Tuning' started by inwood customs, Feb 28, 2018.
  1. Feb 28, 2018 at 5:20 PM
    inwood customs
    inwood customs [OP] Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    In black and white, is the stock fuel pump enough for our supercharged 1grfe with or without any smaller pulley?
    Stictly talking 2nd gen tacoma here
    Im not great at math and Im no brain scientist or rocket surgeon, so I am honestly asking for some help here.
    Heres the part for our trucks yes?
    https://www.autozone.com/fuel-delivery/fuel-pump/delphi-fuel-pump/556193_0_0
    cross reference from
    https://www.partsgeek.com/catalog/2005/toyota/tacoma/fuel_delivery/fuel_pump.html
    specs:
    Maximum Amperage (A): 14.0
    Maximum Free Flow Rate (gph): 26.0
    Outlet Attachment: Male Quick Connect
    Outlet Count: 2
    Outlet Size: 3/8 in
    Package Contents: Fuel Pump Module Assembly, Fuel Tank Seal, Instruction Sheet
    Pump Type: Turbine
    Strainer Included: Yes
    Strainer Location: Internal
    Voltage Rating: 12 vDC
    Working Pressure (psi): 41.0
    Convert GPH to LPH
    http://www.advancedconverter.com/un...onversion/gallons-per-hour-to-liters-per-hour
    to:
    26 gal/h = 98.4207 lt/h
    Is this enough to support the
    claimed 305HP from the magnuson supercharger?
    does this help?
    http://www.raceworks.com.au/calculators/fuel-pump-calculator/
    @Torspd
    @Lucario Runner
    @Gadget@URD
    @anyone
    Sterdog likes this.
  2. Feb 28, 2018 at 5:21 PM
    eon_blue
    Azusa, CA
  3. Feb 28, 2018 at 5:50 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    An amendment to be added. The factory quick connects for feed and return are 5/16 inch fittings
  4. Mar 1, 2018 at 6:41 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    The stock pump is fine for the TRD supercharger on the 4.0L Tacoma.
    The problem is the fuel filter. It starts to clog up and restrict fuel flow around 30,000 miles or so. That will cause the engine to lean out in boost and you can fail the engine.
    This happened in my 05 Tacoma with the URD Mk1 supercharger kit at 30,000 miles. Started dropping fuel presser badly. I replaced the entire tank unit from Toyota and it was over $600. 30,000 miles later, same damn thing happened. That is when I developed the URD Pump/Filter upgrade kit and that has solved the problem. You now have a very easy to replace fuel filter that is outside the tank and just plan on changing it every 30,000 miles and you will be fine.
    URD works very hard to keep the cost of that upgrade very low so as many people can do it as possible so their engines can live long. We include this kit in all the supercharger kit we make, it is that important.
    MY50cal, Sterdog, Roostfactor and 5 others like this.
  5. Mar 1, 2018 at 6:44 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    That's insane. Never seen a fuel filter clog enough to lean out and that's even on e85 that clogs everything. Crazy. Must be a very good filter Toyota made.
  6. Mar 1, 2018 at 11:24 AM
    Gadget@URD
    Well, keep in mind you are trying to get 100 more HP through there than it was designed to flow.
  7. Mar 1, 2018 at 1:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The fact that the supercharger is added as an afterthought to a fuel system initially designed for a vehicle that is expected to run it's intended life in purely NA configuration would make me tell you absolutely not despite the fact that the GPH/ LPH would be okay.
    Remember there is a lot of pressure being applied to the fuel system the moment you start boosting and pumps that are just "good enough" to run a supercharged vehicle makes me feel very strongly against them.
    Take my two cents as you may. Others may feel differently about it.
  8. Mar 17, 2018 at 9:53 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Also keep in mind if you are on the TRD tune and are running the fpr mod, the fuel pump has to provide the correct flow at a pressure above the stock 43.5psi. So if you have say 10lbs of boost the pump has to provide flow at 53.5psi so there is more demand on the pump.
  9. Jul 18, 2018 at 2:07 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    My personal experience lines up with what Gadget said. I had my supercharger installed with less than 5k kilometres on the odometer and I’m just rolling over 45k now. I had weird drops in power when trying to hit wide open throttle on my truck. Luckily I had the URD kit lying around from an impulse purchase and installed it myself. My issues with the truck going full potato seem to be gone.
    I will add my personal feeling is that the Toyota built in filter can’t handle the debree that enters the tank from fueling in the middle of no where from Jerry cans. If you off-road or overland your Tacoma and have the supercharger I’m guessing this issue comes up more often than not. Most people probably just dismiss it as power loss due to age or wear.
