Fuel Pump Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andyd103, Oct 12, 2009.
  1. Oct 12, 2009 at 2:21 PM
    Andyd103
    Andyd103 [OP] Well-Known Member
    Andrew
    New Hampshire
    2002 Tacoma SR5 4WD (3.4L V6)
    Suspension Lift, 40mm Turbo
    Im having the Timing belt changed in my 02 Tacoma because it now has 82k miles and should be done soon, but when i went price shopping because i don't have the time to do it a mechanic also told me the fuel pump should be changed for regular maintenance because its located in the engine bay and is hard to get to and since the belts are being changed it should be changed too.
    I always thought the fuel pumps were on top of the gas tank, can someone tell me if this is true or he's just trying to squeeze a few pennies out of me?
  2. Oct 12, 2009 at 2:34 PM
    spdracr
    spdracr Member
    Lauderdale
    supercharged
    I think you better look for a honest mechanic. The pump is in the gas tank. Are you sure he wasn't meaning the water pump? It is driven by the timing belt and if it starts leaking later you have to do the whole job over again.
  3. Oct 12, 2009 at 3:01 PM
    Andyd103
    Andrew
    New Hampshire
    I know for sure he told me fuel pump, he put it on a bill estimate sheet that is somewhere, and then gave me a 5 minute reason as to why he needed to change it.
  4. Oct 12, 2009 at 3:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The fuel pump is in the tank. Its not a Maintinance item
  5. Oct 12, 2009 at 4:13 PM
    DadsToy
    DadsToy Active Member
    David
    Gainesville, Florida
    2001 Tacoma Double Cab 4x4 V6
    Snorkle, ARB Bumper, Warn Winch, Driving Lights, CB, 2 meter Ham,
    Are you sure he wasn't talking about the water pump?
  6. Oct 12, 2009 at 4:58 PM
    Andyd103
    Andrew
    New Hampshire
    i know its ussually in the tank i was just wondering if this guy was telling me bs and he was so...
  7. Oct 13, 2009 at 5:51 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    sure it wasn't the fuel filter? as stated the pump is in the tank. Filter is a yes it could be changed I did mine at 80k and then did s/c on my 3rz and now that it has got the s/c I may never change it again because I can barely see it. :rolleyes:
  8. Oct 13, 2009 at 9:08 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Andrew, just to cover all the bases here: You have the 3.4 V6 correct?
    You fuel filter should be on the frame rail under the driverside IIRC.
  9. Oct 13, 2009 at 9:11 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I think the mechanic messed up and meant to say water pump. You should change that when you do the timing belt.
