Fuel pump recall on the way
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GreyBaldTaco, Jan 13, 2020.
  1. Jul 1, 2020 at 1:51 PM
    #381
    Eagle46
    Eagle46 My Baby..
    Blake "Blakie"
    Langhorne, Bucks Cty Pa SEPA Philadelphia Area
    2020 TRD Sport DCLB, AT 4X4 VDB
    I heard the 20s have the same fuel pumps??
  2. Jul 1, 2020 at 1:58 PM
    #382
    Eagle46
    Eagle46 My Baby..
    Blake "Blakie"
    I have a 20, and from what I heard the 20s have the same fuel pump
    Chuck X1 likes this.
  3. Jul 2, 2020 at 9:34 AM
    #383
    dewelrTX
    dewelrTX Well-Known Member
    Dewel
    SAN ANTONIO, TEXAS
    2019 Tacoma TRD Off-Road 4x4 DCLB
    I guess you can count me in on having this issue. 2019 TRD OffRoad with less than 22K miles. Notice on a hot day it took awhile to start at work, ran a bit rough and died a few feet after putting it in drive. Local dealership told me it will be 2.5 months before they can get to it.
  4. Jul 2, 2020 at 9:37 AM
    #384
    4x4spiegel
    4x4spiegel Well-Known Member
    Thankfully there hasn't been any reported accidents or deaths due to this issue . I believe toyota has cleared themselves legally with their recall notice .
  5. Jul 2, 2020 at 9:36 PM
    #385
    Mitch65
    Mitch65 Well-Known Member
    Confirms what I have been hearing. We are going to be in the 90s all week here in Ohio so hope I’ll be ok.
    Coyote501 likes this.
  6. Jul 2, 2020 at 9:46 PM
    #386
    Chuck X1
    Chuck X1 Well-Known Member
    Chuck
    NW Indiana
    2020 Tacoma TRD Off Road
    I just put up a post about my 2020 Tacoma stalling out on several occasions. I posted the codes my dealer found on my thread (low fuel pressure and too lean). Unfortunately they just clear the codes and send you on your way, saying they can’t find a problem. Definitely intermittent. Am going back again to try and get them to fix something.
    AKGSD likes this.
  7. Jul 2, 2020 at 9:46 PM
    #387
    Couesfanatic
    Couesfanatic Well-Known Member
    So is your truck sitting on the dealer lot for months on end? I'm in the valley, I can't have this happen to mine out in the middle of nowhere
  8. Jul 3, 2020 at 11:40 AM
    #388
    BigGuy
    BigGuy Well-Known Member
    Tucson Az
    2023 MGM
    No I made them fix it.
  9. Jul 4, 2020 at 2:24 PM
    #389
    Vea
    Vea Well-Known Member
    2018 Tacoma or
    FAQs attached.
    TomTRD, VB25 and indoomitable like this.
  10. Jul 5, 2020 at 2:18 PM
    #390
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Happened to see this the other day on "How It's Made" about low pressure fuel pumps - https://www.youtube.com/watch?v=K8Sx45WPOHk
    There's quite a bit that can go wrong with fuel pumps and I guess that has happened. Outsourcers use outsourced parts, use cheap inexperienced labor, worn out presses, there's a lot that can go wrong with something that is fundamental for engine operation.
    My '97 the Denso in-tank fuel pump died out of warranty. Went to the dealer expert, he printed a wiring diagram, said check these two relays with 12v for proper on/off operation and if they're good then you have to replace the in-tank fuel pump.
    It was the tank fuel pump, after pulling it and hooking it to 12v it would work intermittently. Replaced it with a NAPA for 1/3 of the Denso cost and went about the same miles before I sold the truck.
  11. Jul 6, 2020 at 5:06 PM
    #391
    Kaptain_02
    Kaptain_02 2019 OR
    Just curious about the failures, it looks like heat/temperature could be a factor.
    Do you recall how much gas was in the tank at the time of the pump failure? Any other clues or anything else worth mentioning?
  12. Jul 7, 2020 at 6:04 PM
    #392
    dump1567
    dump1567 Well-Known Member
    2019 Cavalry Blue DCSB TRD OR 4X4 AT
    Mine just went with 30K miles on my 2019. I'm in AZ and it was about 103 out. Started truck and it had erratic idle. Than it started chugging along during acceleration. Check engine light was on. Got it home & it seemed to be running fine. Check engine light was not on the next day and drove fine 35 miles to the dealer.
    Dealer said it was the fuel pump. Gave me another 2020 Tacoma loner & are replacing with another recall fuel pump (not the new upgraded one). Suppose to pick it up tomorrow & will get the new upgraded pump whenever it comes in.
  13. Jul 7, 2020 at 6:16 PM
    #393
    viking15
    viking15 Well-Known Member
    Joe
    Well I have a 2017 that when I gas up and then restart the engine the truck struggles to start I may have to wait 10 minutes or so before it starts up. This only happens when I gas up other than that it starts just fine Taking it to the dealer this week. Also my check engine light stays on
  14. Jul 13, 2020 at 3:06 AM
    #394
    500melon
    500melon Member
    melonhead
    2019 tacoma dcab lb
    2019 Tacoma in Florida, fuel pump dead at 15k. In a rental and it looks like its gonna be a while.
  15. Jul 13, 2020 at 3:52 AM
    #395
    KVTaco
    KVTaco Well-Known Member
    What is involved in the job - empty tank, drop it, replace pump, replace tank, fill and drive?
  16. Jul 13, 2020 at 7:28 AM
    #396
    Kaptain_02
    Kaptain_02 2019 OR
    Can you give us more info?
    Outdoor temperature at the time?
    How much fuel in the tank at the time?
    Hard to start or running odd before it fully failed?
    Any details will help to possibly prolong the life of these pumps
    Mitch65 likes this.
  17. Jul 13, 2020 at 7:34 AM
    #397
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    wait someone got theirs fixed? my dealer said there's still no new fuel pumps to fix it last week
  18. Jul 13, 2020 at 12:14 PM
    #398
    Mitch65
    Bump. I would like to know as well. I have a 19 with 12k miles that I’m hoping makes it until September. Running just fine as of now but I’m nervous about it.
    bbartol and JagoTaco like this.
  19. Jul 13, 2020 at 3:12 PM
    #399
    500melon
    500melon Member
    melonhead
    2019 tacoma dcab lb
    Sure thing.
    2019 trd sport 2wd
    miles--- 15k
    temp -- 92f
    fuel --little over 1/2 tank
    It never completely failed.
    The first warning shot was after visiting an ATM. I got back in the truck and when I started it was running rough. I drove it about 3/4 of a mile back to my house. About halfway back it smoothed out. The second warning shot I came home for lunch about a 5 mile drive a week later. When I came out after eating it started and acted the same way. I shut it off and restarted and it was the same. I shut it off and restarted it again but this time it shook really bad and tach was reading about 300rpm and then the trac off and check engine light came on. I shut it off for about 5 minutes, I restarted it and she was smooth but the check eng light was still on. I drove back to work and finished my day. When I started it to leave work the check eng light was now off. I slapped the laptop on it to check codes and they were p1605 and p0087. I took it to the dealer the next morning and dropped it off as I don't need a third warning shot lol.
  20. Jul 13, 2020 at 3:23 PM
    #400
    500melon
    500melon Member
    melonhead
    2019 tacoma dcab lb
    I also don't want the same pump put back in there. I will wait for the new one. I believe that some of these will fail without any warning.
    The risk is too great for me to take. YMMV
