Fuel pump recall on the way
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GreyBaldTaco, Jan 13, 2020.
  1. Jul 14, 2020 at 5:52 AM
    #401
    ECU4422
    ECU4422 Well-Known Member
    Robocon
    Nissan Frontier
    2019 Tacoma with 15K miles and Florida. I've been trying to keep at least 1/2 tank of gas and so far so good. But yeah, this is making me more nervous. Really surprised Toyota is dragging their feet with this.
  2. Jul 14, 2020 at 6:13 AM
    #402
    bnh032
    bnh032 Active Member
    Brandon
    18' cement trd off road
    Fantastic News
    I’m leaving to go on a 7k mile road trip in September. Knowing my luck this thing will take a crap on me while I’m gone.
    The entire trip will be based in the truck/tent. So I’m Eff’d if it goes out.
    Bowhuntercoop likes this.
  3. Jul 14, 2020 at 8:57 AM
    #403
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    a little story:
    about 20 yrs ago i was off road (cruising logging roads) in WA with a GMC van and started to have hiccups but it usually straightened right out. I though it was bad gas or whatever.
    at end of trip i was doing 70mph on a hwy in 100F heat and the fuel pump totally crapped out with about 1/2 tank left. i had to get towed to a dealer and spent night waiting
    for them to diagnose and install a new pump. i considered myself lucky.
    All sorts of scenarios that would cost the owner $$$ since you guys go off road a lot. I can't believe this well known problem would result in the owner not being
    reimbursed for expenses due to toyota dragging its feet and putting owner at risk.
    Anyone with experience getting toyota to pony up for their failure? do you have to arbitrate/sue? would you win?
  4. Jul 14, 2020 at 9:28 AM
    #404
    bnh032
    Brandon
    Have they extended Toyota Care for any of y’all? I’m at my 2 year mark, but only have 17k miles on my truck.
  5. Jul 14, 2020 at 7:17 PM
    #405
    Mitch65
    Mitch65 Well-Known Member
    You have to remember not every single
    Pump on the recall list will fail. They are failing at a rate that is much to high but my guess would he it’s still well under 1%. Most of the failures I have seen are in extream heat 100+
  6. Jul 28, 2020 at 8:00 AM
    #406
    Justin85
    Justin85 Well-Known Member
    Justin
    I have a 2017 that has been having rough intermittent rough idle and when you give it gas is stumbling. It's throwing a low fuel pressure code. I can let it sit for a few minutes and it cranks up and drives fine. It seems to do this after being cranked up fairly soon after a stop (like running in to a restaurant to pick up food). I haven't had it happen when the truck has been sitting for a while. I am out of warranty and not on the recall list. Hoping I can still have the recall applied since it seems to have the same issues.
  7. Jul 28, 2020 at 3:45 PM
    #407
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    Most fuel pump failures seem to be happening in warm climates. Where are you?
  8. Jul 28, 2020 at 4:00 PM
    #408
    Vea
    Vea Well-Known Member
    2018 Tacoma or
    I’m in the high desert of CA, over one month over 100 everyday. No problems yet. Yes, I’m on the hit list.
  9. Jul 28, 2020 at 8:43 PM
    #409
    Kovaci
    Kovaci Well-Known Member
    Josh
    SD / IN
    2021 Army Green DCSB TRD Off Road
    2019 with ~26k miles and just had a failure 2 weeks ago. Pulled out of a parking lot and truck was shuddering, tried to accelerate and nothing happened. CEL came on so I pulled the code and got a P0087 (Fuel Rail / System Pressure - Too Low) - tank was a little under half at this point. Filled it up and have been keeping it above half and CEL went away and so did the issues.
    Took it to the dealer today and they verified the issue and code was related to the recall but there's nothing they can do about it right now... They also said they're expecting the remedy to come in September.
  10. Jul 29, 2020 at 5:04 AM
    #410
    Justin85
    Justin
    Southwest Arkansas. Right on the Texas border. It's hot.
  11. Jul 29, 2020 at 5:12 AM
    #411
    TacoTheTaco
    TacoTheTaco Well-Known Member
    DC
    2018 TRD Sport 4x4 DBL Cab
    You’re lucky. Mine shuttered then cut off in rush hour traffic on my way home. Luckily I didn’t get hit and with a little cussing and it started back up and got me home since I was only about a mile away. The dealership wanted it to be towed there to be fixed with no lease car and my other truck was down as I was running exhaust on it. Talk about bad timing.
  12. Jul 29, 2020 at 8:16 AM
    #412
    Justin85
    Justin
    Im at the stealership now. They are charging me $130 for diagnostics and then recommending that I let them replace the fuel pump at a cost ofnclose to $1000. Im going to call Toyota and see if they will cover it under the recall.
  13. Jul 29, 2020 at 8:28 AM
    #413
    Kovaci
    Josh
    SD / IN
    Toyota care is just for regular maintenance. As long as your VIN is listed on the recall you should be covered for the fuel pump fix.
    How many miles on the truck? They tried to pull the same thing with me regarding diagnostics and I told them it should be covered under the drivetrain warranty.
  14. Jul 29, 2020 at 9:00 AM
    #414
    danwray
    danwray Traitor
    Dan
    Kentucky
    2021 Ford F150 XL 4x4 2.7 ecoboost
    So they're going to replace with a known faulty part and charge you for it? I'd go to another dealer fast
    Jasonstacoma likes this.
  15. Jul 29, 2020 at 9:15 AM
    #415
    Justin85
    Justin
    I have 68000 miles
  16. Jul 29, 2020 at 9:16 AM
    #416
    Justin85
    Justin
    They are the only dealer in my area. My vehicle is not listed in the recall and it is out of warranty. I am currently on the phone with Toyota to open a case and see if they will replace it.
  17. Jul 29, 2020 at 9:25 AM
    #417
    Outdoorsy_Yota
    Outdoorsy_Yota Hella-Known Member
    duhbondo JIW Local 378
    Bay Area
    17 DCLB TRD OR LOL
    LOL exactly... cracks me up people complaining of thinking they missed the guinea pig models by buying a 19/20 model to only complain about fuel pumps, creaks, CC not working and paint chips lol
  18. Jul 29, 2020 at 12:41 PM
    #418
    Justin85
    Justin
    Toyota agreed to pay for my repair.
    Siblue, NC_Pinz, DanoTay and 2 others like this.
  19. Jul 29, 2020 at 4:33 PM
    #419
    texbaz
    texbaz Well-Known Member
    "Buffalo Creek" TX
    2018 Tacoma Silver Sky Metalic 4WD DCSB TRD OR
    I'm sure you know its not really 1000.00 job dropping your tank and changing the pump. new pump 260.00 and new pump as an assy 360.00. I'm 65yr, Id drop that tank before letting them do it for 1000.00. or at least buy the stuff find out what local car guy will charge you
  20. Jul 29, 2020 at 8:04 PM
    #420
    Justin85
    Justin
    Spoke with Toyota and they are covering it
    Brownie_Man and Jasonstacoma like this.
