Fuel pump recall on the way
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GreyBaldTaco, Jan 13, 2020.
  1. Oct 16, 2020 at 10:30 AM
    #681
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Thanks for the info. I ended up buying from Lassen in Albany because all the Portland area dealers told me they couldn't order the truck I wanted. Called Albany Toyota and they said no problem explain the process and made it very easy would totally recommend going to them again.
    I hate having to take my truck in for work I do everything I can myself. Unfortunately don't feel like dropping the fuel tank to replace a pump and doubt Toyota would give me one anyway.
  2. Oct 16, 2020 at 10:46 AM
    #682
    danwray
    danwray Traitor
    Dan
    Kentucky
    2021 Ford F150 XL 4x4 2.7 ecoboost
    Pays to try another dealer, I dropped off at 9, was ready by noon, and had a free loaner for the morning. Polar opposite of the experiences I've had at the dealer we bought it from.
  3. Oct 16, 2020 at 12:24 PM
    #683
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    No prob! My truck is done. Exactly 5hrs on the dot. Won't be able to get it until later though.
    I just wanted a basic SR5 which most dealers had at the time. Kendall of Eugene and Kendall of Bend were the cheapest by far and I emailed all Oregon dealers. Went back and forth over a few months before I got the numbers I wanted.
    02Duck[QUOTED] likes this.
  4. Oct 16, 2020 at 12:31 PM
    #684
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    Toyota tinkers with all the wrong stuff in the name of technology
  5. Oct 16, 2020 at 2:40 PM
    #685
    pelts79
    pelts79 Well-Known Member
    Just got mine done. It took a week for the pump to come in and about 4 hours for the install. Glad it's taken care of, although I wasn't overly concerned about it failing. I did a 3600 mile round trip this summer being aware of the recall.
  6. Oct 17, 2020 at 11:10 AM
    #686
    Mitch65
    Mitch65 Well-Known Member
    Mines done so far so good! Only bummer is the tech must have had gas on his boots or something bc when I got in my truck it smelled like gas.
  7. Oct 19, 2020 at 8:12 AM
    #687
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    I recently bought a 2018 TRD. Was told they already did the recall. My engine light came on and I took it in (different dealership I bought it out of state). They said it was done wrong and a seal went bad. Now I’m on a two month wait with my truck sitting at the dealership!
    Rockefelluh likes this.
  8. Oct 19, 2020 at 11:24 AM
    #688
    TnTuna
    TnTuna Well-Known Member
    3rd Gen Tacoma
    The replacement was completed on mine in about 2 hours. No issues so far. I did come in with about 2 gallons left in my tank.
  9. Oct 20, 2020 at 6:44 AM
    #689
    dal3_gribble
    dal3_gribble Well-Known Member
    Crew Cab SB TRD Offroad
    Dropped mine off this morning. Sounds like Toyota's supply chain is filled up now. There were a bunch of vehicles in for the recall when I dropped mine off.
  10. Oct 20, 2020 at 6:48 AM
    #690
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    :thumbsup: good idea
    Rock Lobster[QUOTED] likes this.
  11. Oct 20, 2020 at 10:59 AM
    #691
    GeorgiaAsh
    GeorgiaAsh Well-Known Member
    Acworth, Georgia
    2019 Silver SR5 DCSB
    Just got mine. Called, said part had to be ordered and should be in by the end of the week. Heard nothing. Gave them another week, heard nothing. Called yesterday, they asked when I wanted to come in. Had a 10am appointment, got out around 1
  12. Oct 20, 2020 at 2:53 PM
    #692
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I took mine in with 3/4 tank of gas.
    Service manager said they have a lift that holds the tank while they swap the pump.
    Still had 3/4 tank when I got it back.
  13. Oct 20, 2020 at 3:13 PM
    #693
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    They requested I try to have it less than half full. They insinuated that it wouldn't be a deal breaker if I didn't, but I'll at least be polite and honor that request. Besides, it coincides with my day off, which is easier than having to shuffle this repair while still putting in a full 9. :hattip:
  14. Oct 20, 2020 at 6:40 PM
    #694
    wood714
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I reckon they wanted me to bring mine up ASAP, so they'd get their 4Runner back they loaned me.
  15. Oct 20, 2020 at 6:42 PM
    #695
    Bishop84
    Bishop84 Well-Known Member
    It's not that bad on Tacoma.
    Tundras and Siennas are a mega bitch with a full tank.
  16. Oct 21, 2020 at 5:44 AM
    #696
    ArkansasBuffalo
    ArkansasBuffalo Active Member
    F
    Northeast Arkansas
    2018 Cement TRD OR 4X4
    I just got this done Monday. This morning (Wednesday) my check engine light came on and my cruise control is not working.
    Could this be related or just a coincidence?
  17. Oct 21, 2020 at 5:57 AM
    #697
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    It's most definitely related. Call your SM and reschedule. Some of the hoses for the evaporative system (there is a vacuum pump on the fuel tank) are disconnected when the fuel tank is dropped. If one of the connectors on the evap hoses leaks it will fail the self evap test when the truck sits for over 5hrs and CEL comes on. The OBII code is P0456. Check your gas cap too, clear the code and reseat your gas cap. It could be something simple?
    Those fuel evap hose connections have small O rings, there is a chance the tech might have "rolled" a O ring when reassembling the evap hose connections.
    The tech can smoke test the fuel lines to locate the exact fuel evap leak if that's what's going on with your truck. It depends on which OBDII code your truck is emitting. The tech can follow up with the self test by initiating it thru a laptop using Techstream software.
  18. Oct 21, 2020 at 6:27 AM
    #698
    ArkansasBuffalo
    F
    Northeast Arkansas
    Thanks a lot!
    I did check the gas cap. I was going to call the service department....but I just decided to show up. Parked my truck right i Front of the door and then calmed down and politely told them the issue and that this had never happened before I got the new fuel pump installed. They are looking at it now.
  19. Oct 21, 2020 at 11:21 AM
    #699
    john_t
    john_t Well-Known Member
    MA
    2018 Tacoma MGM Limited DCSB
    This (almost) happened with mine. I had asked for an inspection sticker to be done after the recall. They said the inspection was delayed since the recall repair resulted in a CEL. They cleared it somehow - not sure if it was just a reset or what.
  20. Oct 21, 2020 at 4:52 PM
    #700
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    Now that recalls are being done, can any of you fellow TW members post the part numbers that Toyota is replacing? Or at least a pic of the work order.
    Thanks
