Fuel pump relay
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joshuaW98, Aug 15, 2023.
  1. Aug 15, 2023 at 5:09 PM
    joshuaW98
    joshuaW98 [OP] Member
    Joshua
    2017 Toyota Tacoma
    I have a 2017 Tacoma. My truck will turn over but not start. It has a brand new battery. I’m suspecting the fuel pump relay maybe. Does anyone know where that’s located?
  2. Aug 15, 2023 at 5:13 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did the no-start happen right after the battery was replaced? Have you tried cranking it with the gas pedal pushed down slightly. It may just need a throttle body cleaning which is common after battery replacement
    What makes you suspect a fuel pump problem? Does it run on starting fluid? Does it have spark?
  3. Aug 15, 2023 at 5:44 PM
    joshuaW98
    Joshua
    2017 Toyota Tacoma
    It did not run on starting fluid.
  4. Aug 15, 2023 at 5:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Then it's probably not a fuel issue
    Try pushing the gas pedal and cranking it
  5. Aug 15, 2023 at 5:56 PM
    joshuaW98
    Joshua
    2017 Toyota Tacoma
    I also did that and no luck. :(
  6. Aug 15, 2023 at 5:58 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is there an anti-theft or alarm light flashing?
  7. Aug 15, 2023 at 6:28 PM
    joshuaW98
    Joshua
    2017 Toyota Tacoma
    Yes there is.
  8. Aug 15, 2023 at 6:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Do you have a spare key to try?
    TnShooter likes this.
  9. Aug 15, 2023 at 6:38 PM
    joshuaW98
    Joshua
    2017 Toyota Tacoma
    Upon reading a couple other forums I seen to try another key like you are asking and I did try. Nothing different.
  10. Aug 15, 2023 at 6:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is the anti-theft light flashing with the key in the ignition?
    On both sets of keys?
    If so, it is not going to start until the light stops flashing.
    The flashing light means the security system isn’t seeing the key. (Or the correct key)
  11. Aug 15, 2023 at 6:43 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Do the door locks respond to the key fob, lock and unlock?
    If the alarm isn't cooperating you kinda have to start there. Either take it to the dealer or find a shop with capability to diagnose it and program keys or whatever
    It's the alarm system that's keeping it from starting. It'll cut fuel or spark or sometimes both
  12. Aug 15, 2023 at 6:50 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Your other post shows your stereo started acting up are replacing your battery, not even two months ago. I’d get this to a good tech and have them run down systems, I’m guessing something is F’ey with the electronics.
    also address any aftermarket electronics, definitely the first place to start.
    https://www.tacomaworld.com/threads/no-audio.804863/
  13. Aug 15, 2023 at 7:01 PM
    joshuaW98
    Joshua
    2017 Toyota Tacoma
    Ok so I go in and turn my truck over. My anti-theft light is flashing just as these other individuals are saying. I have a viper remote start system installed. It was installed about 6 years ago. Battery was changed out today because it was tested “bad”. I guess my best bet is to take it to a dealer. I was hoping someone had the same issue and could help me get in the right track
  14. Aug 15, 2023 at 7:02 PM
    joshuaW98
    Joshua
    2017 Toyota Tacoma
    lock and unlock does respond. I think the issue is over my head so dealership may be next.
  15. Aug 15, 2023 at 7:12 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    If your battery didn’t even make it 2 months,,, yeah,,, you’ve got other problems.
    Sorry, I don’t think anyone can do other than guess. It needs to see a real tech.
  16. Sep 6, 2023 at 3:37 AM
    joshuaW98
    Joshua
    2017 Toyota Tacoma
    Just coming back to let you all know that I found the issue to be the transponder key
    coil.
    Easy 30-dollar fix.:):amen:
    TnShooter and Chew like this.
  17. Sep 6, 2023 at 4:39 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Good news.:taco::taco::taco:
