Fuel pump replacement. Is there an easy way?
Discussion in 'Technical Chat' started by jax45, May 29, 2012.
  1. May 29, 2012 at 1:01 PM
    jax45
    jax45 [OP] Member
    Sharpsburg Ga.
    2005 PreRunner
    Has anyone replaced the fuel pump on a 2nd generation Tacoma? Just curious if its easier to lift the bed or drop the tank. Been fighting the PO171/174, couldn't admit what was apparent. The truck has some smart electronics and it will try to compensate but when the temp goes up the code starts popping up. Fuel pump had 27 psi. Not enough.
  2. May 29, 2012 at 10:51 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
    Your Vehicle: 2010 Toyota Truck Tacoma 4WD V6-4.0L (1GR-FE)
    Removal 1GR-FE FUEL: FUEL TANK: REMOVAL
    1. DISCHARGE FUEL SYSTEM PRESSURE
    1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
    2. REMOVE NO.1 FUEL TANK PROTECTOR SUB-ASSEMBLY (WITH OFF ROAD PACKAGE)
    3. DISCONNECT FUEL TANK MAIN TUBE AND FUEL TANK RETURN TUBE
    (a) Remove the fuel pipe clamp. (b) Disconnect the fuel tank main tube and fuel tank return tube.
    (1) Pinch the retainer as illustrated, then pull the fuel tube connectors out of the pipes. NOTICE:
    * Remove any dirt and foreign objects from the fuel tube connector before performing this work. * Do not allow any scratches or foreign objects on the parts when disconnecting, as the fuel tube connector has the O-ring that seals the pipe. * Perform this work by hand. Do not use any tools. * Do not forcibly bend, twist or turn the nylon tube. * Protect the disconnected part by covering it with a vinyl bag after disconnecting the fuel tube. * If the fuel tube connector and pipe are stuck, push and pull to release them.
    1. REMOVE FUEL TANK ASSEMBLY
    (a) Loosen the clamp bolt. (b) Disconnect the fuel breather tube.
    (1) Remove the checker of the fuel tube connector from the pipe.
    (2) Pinch the retainer of the fuel tube connector, then pull the tube connector out of the pipe. NOTICE:
    * If the fuel tube connector and pipe are stuck, push and pull to release them. (c) Hold the fuel tank using the mission jack.
    (d) Remove the 2 fuel tank bands.
    (1) Remove the 2 bolts.
    (2) Remove the 2 clips and 2 pins, then remove the 2 fuel tank bands. (e) Slightly jack the fuel tank down and separate the fuel tank to filler pipe hose from the inlet pipe.
    NOTICE:
    Slowly jack down the fuel tank so as not to tear the wire harness and hose.
    (f) Remove the fuel pump cover. (g) Disconnect the fuel pump connector. (h) Disconnect the fuel tank vent hose.
    (1) Pinch the retainer and pull the fuel tank vent hose connector out of the charcoal canister to disconnect the fuel tank vent hose from the charcoal canister. NOTICE:
    * Remove any dirt and foreign objects from the fuel tank vent hose connector before performing this work.
    * Do not allow any scratches of foreign objects on the parts when disconnecting, as the fuel tank vent hose connector has the O-ring that seals the pipe.
    * Protect the disconnected part by covering it with a vinyl bag after disconnecting the fuel tank vent hose.
    * If the fuel tank vent connector and pipe are stuck, push and pull to release them. (i) Remove the fuel tank assy.
    1. REMOVE FUEL TANK MAIN TUBE AND FUEL TANK RETURN TUBE
    (a) Remove the 2 joint clips, then remove the fuel tank main tube and fuel tank return tube. NOTICE:
    1. REMOVE FUEL SUCTION WITH PUMP & GAUGE TUBE ASSEMBLY
    NOTICE:
    Protect the connector and tube joint with masking tape or equivalent to prevent any foreign objects from sticking to them. Clean any dirt and foreign objects from the fuel suction tube assy before removing.
    (a) Using a SST, loosen the retainer. SST : 09808-14020
    09808-01410
    09808-01420
    09808-01430
    HINT
    The ribs on the retainer can be fitted into a tip of the SST.
    (b) Remove the retainer. (c) Pull the assy out of the fuel tank. NOTICE:
    Be careful not to bend the arm of the sender gauge.
    (d) Remove the gasket from the fuel tank.
    1. DRAIN FUEL
    2. REMOVE FUEL TANK TO FILLER PIPE HOSE
    (a) Loosen the clamp bolt, then remove the fuel tank to filler pipe hose.
    1. REMOVE NO.1 FUEL TANK PROTECTOR
    (a) Remove the 4 clips, then remove the fuel tank protector.
    or try the bed. but would check to seewhats attached to it
  3. May 31, 2012 at 3:35 PM
    jax45
    jax45 [OP] Member
    Sharpsburg Ga.
    2005 PreRunner
    Thanks for the info. Aptec, it is certainly appreciated.
  4. May 31, 2012 at 4:46 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    sorry the pics will auto rotate. the info service i subscribe to is kinda protective of their material
  5. May 31, 2012 at 5:00 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I dropped the tank pretty straight forward as directions above. I chose this route due to not having a second set of hands to help remove the bed.
  6. May 31, 2012 at 5:33 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    last time i was under there it didnt look to bad. im glad it went well for you.
  7. May 31, 2012 at 5:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    get a friend to help remove the bed. Easy as pie.
    HBMurphy likes this.
  8. May 31, 2012 at 6:06 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    pump install if you need it:rockband:
    • fb1.pdf
      File size:
      35 KB
      648
    • fp2.pdf
      File size:
      50.4 KB
      266
    • fp3.pdf
      File size:
      47.8 KB
      256
    • fp4.pdf
      File size:
      48.4 KB
      267
    • fp5.pdf
      File size:
      44.7 KB
      198
    • fp6.pdf
      File size:
      49.2 KB
      234
  9. Jun 1, 2012 at 3:36 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    As a previous S-10 owner who has changed 3 pumps in the last 9 years I recommend this... remove all bed bolts from the left side. loosen (don't remove) the right side bolts. Use a jack ON TOP of the left side wheel to lift the bed up far enough to get access to the tank. Leaving the right side bolts in installed keeps the bed from moving out of place.
    I once had to do this in a grocery store parking lot 225 miles from home:mad:
    FishingInSand, KTM753 and wheeliest like this.
