Fuel pump replacement, now engine and RPM acting weird. HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco350k, Oct 4, 2011.
  1. Oct 4, 2011 at 1:37 PM
    taco350k
    taco350k [OP] New Member
    andy
    milford, oh
    95 xtd cab
    I recently had my original fuel pump replaced at around 340-345000 miles on my 1995 toyota tacoma xtd cab, 3.4L 4X4. The original was in there before and for a week it wouldn't start up. now that the fuel pump is replaced it starts up fine but acts weird when its running.
    1.) When I start it up and it gets warmed up, it Idles right at 2,000 RPM, before it idled around 1,000 or 1250
    2.) No problem when im actually moving forward, but when I'm in neutral and applying the brakes and above 20MPH, it revs up and down between 1,250 RPM and 2,000 RPM and goes back and fourth up and down until exactly when I hit 20 MPH, then it jumps back up to 2,000 RPM and stays there (just like when im at an idle stop). If I let off the brakes though while I'm above 20MPH and still in neutral, it stops hovering between 1250 and 2000, and stays right at 2,000 just like when its idling, but as soon as i touch the brakes and am over 20MPH it will jump up and down.
    3.) I dont know what it is and really would like to get it fixed because I plan on keeping my truck of course, its just the gas mileage has dropped to somewhere around 14-16 MPG (normally 21 or 22).
    PLEASE HELP. anyone who has had to change their fuel pump or has any idea what this problem is (electrical, fuel pump regulator etc.) or what I can do please let me know. I would GREATLY appreciate it.
    All the best
  2. Oct 4, 2011 at 7:33 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Check you IAC with a meter make sure its in check. Iac controls your idle.
    Did you replace your fuel filter when you changed your pump?
  3. Oct 4, 2011 at 7:39 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Might be running a little lean? :notsure: that would cause it to have a higher idle I believe.
  4. Oct 4, 2011 at 10:29 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    x2...
    i recently had my fuel pump go bad and replaced... after that, it started running badly, check engine light kept coming on, so i took it to my mechanic... turned out my IAC sensor went bad too, so swapped it out and it ran good as new...
