FUEL PUMP RFI ( ham radio related)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cavmedic, Sep 4, 2021.
  1. Sep 5, 2021 at 1:04 PM
    #81
    brfield
    brfield Well-Known Member
    2020 TRD Off Road
    Have you tried doing a quick and dirty foil shielding either on top of the pump or between the pump and antenna to see if you can block the most direct path?
  2. Sep 5, 2021 at 1:05 PM
    #82
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    From the schematic, do not add filtering between the ECU and pump. Pump motor with its 4, likely differential 2 phase, leads will not respond well. Do filter the power leads to the ECU no harm there. You already have an experiential feedback to tell you if that will work or not. Over analyzing, while I get it, it would be good to narrow down the source; in the end you are looking for results. Yes, do power both radio power leads to the battery as a best practice and add your chokes there as well. I understand it is mostly the antenna bringing in the unwanted RF, but if the DC input has the same frequency removed there is much less likely to have a feedback loop making your noise floor on the resulting audio worse than it really is.
    MOC221_[QUOTED] likes this.
  3. Sep 5, 2021 at 1:06 PM
    #83
    Cavmedic
    Cavmedic [OP] Well-Known Member
    Pottstown PA
    Only way to get close to that would be to drop the straps , and lower the tank and remove the filler neck . If I’m going through all that , it will be to either add filters on the lines or yank the pump completely.
  4. Sep 5, 2021 at 1:11 PM
    #84
    brfield
    2020 TRD Off Road
    If I was yanking the pump I’d be looking at doing a ground strap. At worst you’ll have to dremel a bit of the plastic housing to get it to fit, but that can be sealed up with some epoxy pretty easy. Hose clamp a braided strap to the exterior of the pump and then find a decent spot on the frame.
  5. Sep 5, 2021 at 1:11 PM
    #85
    Cavmedic
    Pottstown PA
    Well, thanks for the explanation on the output side of the ecu. That’s what I was originally looking for. BUT I did use an exact radio , on a different power source than the onboard power system and the issue is still there, eliminating any power wiring issues. Also shown in the videos using two different spectrum analyzers…
    so I’m beginning to think that the only real answer to this would be to get a braided shield wire directly to the pump housing and bond that to the frame and hopefully drain the RFI that way.
    MOC221_ and VE7OSR[QUOTED] like this.
  6. Sep 5, 2021 at 1:26 PM
    #86
    Cavmedic
    Pottstown PA
    Or just yank out the radio and say hell with it………
  7. Sep 5, 2021 at 1:33 PM
    #87
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    I did not read thru the whole thread but i looked at the early measurements and did search for "brush" and "brushless" in the thread and got no hits.
    Have you considered that and could brushes be responsible for offending RF?
  8. Sep 5, 2021 at 2:32 PM
    #88
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Have you seen what it looks like on a spectrum analyzer? oops missed that you posted a video I missed it?
  9. Sep 5, 2021 at 2:33 PM
    #89
    Cavmedic
    Pottstown PA
    I do not believe that PWM motors are brushed but brushless or magnetic driven. But I could be wrong.
  10. Sep 5, 2021 at 2:43 PM
    #90
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    OK found it if its PWM there would be significant spikes equally spaced.
  11. Sep 5, 2021 at 2:44 PM
    #91
    Cavmedic
    Pottstown PA
    Check out the first video from the spectrum analyzer
  12. Sep 5, 2021 at 2:51 PM
    #92
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    To kind of jump into this thread late.
    #1. If there is a PWM circuit at the fuel pump what harm would it be to create a twisted pair circuit? Would achieving this reduce RFI? I know that twisted pair circuits are designed to limit interference in AC circuits like sensors.
    #2. The ECU more than likely controls the Pulse Width Modulation of the fuel pump through internal grounding in the ECU. Can a grounded ECU cause your RFI and if so can you place a filter at the ECU ground?
  13. Sep 5, 2021 at 4:51 PM
    #93
    Cavmedic
    Pottstown PA
    I dont believe that twisted pair would prevent signal from being radiated from the source onto the harness like toroids would "detune" the resonant frequency by adding inductance.
    as best as i can tell , that ECU is grounded as its mounted directly to the frame and has a substantial metal plate around it. It would most likely be shielded to keep ingress out.
    VE7OSR likes this.
  14. Sep 5, 2021 at 4:53 PM
    #94
    Cavmedic
    Pottstown PA
    Yeah it was a few pages back, but to save your thumbs
    https://youtu.be/ICAhlBrbsSs
  15. Sep 5, 2021 at 4:55 PM
    #95
    pdxTacoSR5
    PDX area
  16. Sep 5, 2021 at 5:24 PM
    #96
    Cavmedic
    Pottstown PA
    Looking at the spikes on the analyzer, they looks almost identical to the RFI I get from my
    Neighbors water pump in his KOI pond. His pump uses a “magnetic drive” motor that has a flow controller. That fancy term was on the box for it. Aka a variable frequency drive or PWM’d
    pdxTacoSR5[QUOTED] likes this.
  17. Sep 5, 2021 at 5:35 PM
    #97
    pdxTacoSR5
    PDX area
    After finding that article about brushed and PWM, I called a friend who designs motors (disk drives, etc) and I showed him that article
    and he went ballistic. He thought it was ridiculous and he is an expert in this stuff. I am not. So that someone did something with a PWM power supply to a brushed motor is apparently VERY non standard.
    He would take bets the motor is brushless if it is PWM, though he does not know anything about fuel pumps and he admits it would be cheaper to use a brushed motor...hmmm...toyota....probably not though.
    It was a very entertaining phone call..had to calm him down. :)
    ...and he has a koi pond.
    SR-71A likes this.
  18. Sep 5, 2021 at 5:53 PM
    #98
    Cavmedic
    Pottstown PA
    I think the brushless motors last a lot longer as you never have that friction wearing brushes , plus I believe a brushless is more efficient as well.
    VE7OSR and pdxTacoSR5 like this.
  19. Sep 5, 2021 at 5:58 PM
    #99
    pdxTacoSR5
    PDX area
    many advantages to brushless including not sparking in the tank. supposed to be no oxygen in there but could ruin your day being wrong.
    VE7OSR likes this.
  20. Sep 6, 2021 at 3:53 AM
    #100
    Cavmedic
    Pottstown PA
    Brushed would be a RFI nightmare. Not sure if you are old enough to have this happen , but having an antenna for analog TV back in the day , and your parents using a mixer, you used to get the lines across the tv screen, or an old car from the 70 or 80’s and the blower motor or windshield wipers would make noise through the “high fidelity” center dash speaker….
    MikeyD.25, SR-71A and MOC221_ like this.
