Fuel pump?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Beermaker, Feb 6, 2018.
  1. Feb 6, 2018 at 6:11 PM
    Beermaker
    Beermaker [OP] New Member
    I have 2016 Tacoma.I can turn the truck of and still here something running under the truck near the fuel tank The only way to stop it is to start the truck and then turn off again.Sometimes this has run for hours after use.It sounds like a solenoid stuck on any thoughts.
  2. Feb 6, 2018 at 6:14 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It is normal, the truck runs a test about 5 hours after you shut it off, it's in the Owners Manual
    hiPSI likes this.
  3. Feb 6, 2018 at 6:15 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Are you saying it will run for hours after use or runs after hours after use?
    If the latter, probably just the EVAP purge.
    shakerhood likes this.
