fuel pump
Discussion in 'New Members' started by tar81, Apr 26, 2021.
  1. Apr 26, 2021 at 1:33 PM
    tar81
    tar81 [OP] New Member
    hi everyone, my taco had a recall for the fuel pump, alas they put a new fuel pump in Oct of 2020 and replaced a hose. I have lost mpg's. they are blaming the winter blend I said nonsense had no problem all winter long in 2020. the service manager stated he has been working on Toyota's for 25 years, I said, good for you, now replace the fuel pump and hose you guys put in. He said the fuel pump has nothing to due with mpg's. seriously!!!!
  2. Apr 26, 2021 at 1:41 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Fuel is metered by injectors not pump.
    RedWings44 and buckhuntin-tacoma like this.
  3. Apr 26, 2021 at 1:41 PM
    tar81
    i have call Toyota customer service again
  4. Apr 26, 2021 at 1:44 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Welcome to TW!
    Honestly, I don't think they are wrong saying that the fuel pump and hose have nothing to do with MPG. They likely disconnected your battery while they did the work, so the truck has to re-learn everything.
    I'd give it some time before worrying about the fuel pump change causing your MPG issue.
  5. Apr 26, 2021 at 1:48 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I gotta agree Winter Blend Any Extra Idle Time??
    How many MPG did you lose ??
    Are you down Below 9 mpg That is when I get Concerned.
    Are you smelling gasoline or seeing it running off the Tank because the Line is leaking??
    RedWings44 likes this.
  6. Apr 26, 2021 at 3:24 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  7. Apr 26, 2021 at 3:34 PM
    tar81
    like I said, the fuel pump was fixed in Oct no smell of gas. I believe I have given the truck plenty of time to relearn. From 22/20 mpg to 16 to 18 mpg non stop highway travels
  8. Apr 26, 2021 at 3:37 PM
    tar81
    i also asked the service manager if the gas filter or anything else could be causing the problem he said my 2019 taco doesn't have gas filters??????? seriously
  9. Apr 26, 2021 at 3:41 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    My mpg went from 17-18 in the summer to 15's in the fall and 14 during the winter. So the timing of your pump replacement seems to line up pretty well with the time frame winter gas starts to show up. I'd give it more time now as it warms up and the summer gas returns in the next month.
  10. Apr 26, 2021 at 3:46 PM
    tar81
    however during the winter of 2019/2020 I never lost mpg's
  11. Apr 26, 2021 at 3:51 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    There is no traditional in-line fuel filter. There is the "sock" over the gas tank pickup which is a very fine mesh. That's it for the 2nd gen Tacomas. Haven't seen any issues related to lack of fuel filtration.
  12. Apr 26, 2021 at 4:36 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Well then are your rings shot checking the oil for gasoline??
    Does the Exhaust burn black all the time to the point it looks like a smoke screen.
    The missing Gasoline is either draining in the oil burning causing constant black smoke or leaking which one is it doing??
  13. Apr 26, 2021 at 4:42 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    The pump seriously has nothing to do with fuel mileage.
  14. Apr 26, 2021 at 4:46 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Most modern cars no longer come with fuel filters. The fuel pumps are in the tanks and there is a fuel sock before the pump. Hell, even my 2008 Canyon didn't have a fuel filter. You can always splice one in if you like. But, if you're not traveling internationally, chances are you won't need one.
    Also, yes, winter blend fuel is a thing. Colder weather also affects temp as the ECU has to compensate to make the truck run properly. My truck was getting around 16-18 highway (70 MPH) in the winter and has seen 21 and 22 now that it has warmed back up.
  15. Apr 28, 2021 at 5:52 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  16. Apr 28, 2021 at 6:08 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Welcome aboard, now wipe that egg off your face!
    coolrunnings82 likes this.
  17. Apr 28, 2021 at 2:18 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    The fuel pump won't effect the MPG, and when they change it, they'll disconnect the battery which will reset the MPG. The MPG average is up to the driver tbh. I used to average 15 mpg on stock and then it went all the way up to 19 overtime without changing anything. Im back down to 15 with lift wheels and tires.
