Fuel rail
Discussion in 'Performance and Tuning' started by superwhite, Feb 13, 2017.
  1. Feb 13, 2017 at 5:08 PM
    superwhite
    superwhite [OP] Well-Known Member
    sean
    Western NC
    07 double cab 4x4
    Dana 60 rear Chevy 63's shackle flip mid travel gears lockers and 38's in progress
    Working on running new fuel lines for my 07 and neglected to mark which side of the rail is the supply side. Do our trucks have the regulator before the rail or does it feed into the rail and regulate after?
  2. Feb 14, 2017 at 4:45 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Driver side: supply. Passenger side: return. Regulator at end of passenger side.
  3. Feb 14, 2017 at 6:22 AM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Thank you sir!
