Fuel sending unit to instrument cluster
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 16toyotaco, Jan 9, 2021.
  1. Jan 9, 2021 at 5:48 PM
    16toyotaco
    16toyotaco [OP] Member
    Hello,
    Does anyone know where the green and beige wires from the fuel sending unit connect to the fuel gauge in the instrument cluster?
    2016 tacoma sr
    4 cylinder
    Extended cab
    Thank you for your help.
  2. Jan 9, 2021 at 7:49 PM
    caribe makaira
    Caribbean, Puerto Rico
    TnShooter, Toycoma2021 and Skydvrr like this.
  3. Jan 9, 2021 at 9:07 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Well, that was certainly a fast and succinct answer. caribe makaira what program is that wiring diagram from?
  4. Jan 10, 2021 at 5:56 AM
    16toyotaco
  5. Jan 10, 2021 at 10:04 AM
    caribe makaira
    No problem, what are you working on with the fuel gauge?
  6. Jan 10, 2021 at 11:00 AM
    16toyotaco
    Just trying to get the fuel gauge to work. Just stopped working.
  7. Jan 10, 2021 at 11:16 AM
    caribe makaira
    Damn. The sending unit is part of the fuel pump.
  8. Jan 10, 2021 at 12:33 PM
    16toyotaco
    replaced the snding unit in tank. checked resistence, ok. plugged obdII into dash and fuel guage worked, so i know its not the guage. has to be in wiring. dont know what else to check.
  9. Jan 10, 2021 at 12:56 PM
    caribe makaira
    Maybe Combo Meter is hinting it's about to go...
  10. Jan 10, 2021 at 3:13 PM
    16toyotaco
    Don't think so. Worked when obdII was plugged into dash. Checking harness from fuel tank t instrument cluster tomorrow. Really appreciate everything you sent me.
  11. Jan 10, 2021 at 3:16 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Maybe Captain Obvious, but disconnect any aftermarket doodads if you've add any.
  12. Jan 10, 2021 at 3:19 PM
    16toyotaco
    Thanks gonna do that when I check harness. Thanks again for the help.
  13. Jan 10, 2021 at 3:20 PM
    caribe makaira
    OBDII reader is indicating fuel amount, but Combination Meter is not showing = Combo Meter AFU.
