Fuel Shutoff? Rolled my truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TurdGenBrah, Dec 2, 2017.
  1. Dec 3, 2017 at 8:08 AM
    #61
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Definitely hydrolocked. :popcorn:
    wilcam47 and scottalot like this.
  2. Dec 3, 2017 at 8:08 AM
    #62
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    No way they'll warranty something like this. Pulling the plugs is not that difficult. Just make sure to thread them back in by hand and torque them to just under 20 ft lbs.
    t.hornstra and scottalot like this.
  3. Dec 3, 2017 at 8:08 AM
    #63
    crisanalex
    crisanalex Well-Known Member
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    You shouldnt hurt anything pulling spark plugs and manually cranking the motor worst thing that happens is nothing happens and you put the spark plugs back in. GL OP.
    scottalot likes this.
  4. Dec 3, 2017 at 8:12 AM
    #64
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    What he said is the correct process. If there is oil (or any fluid) in the cylinders, it may as well be concrete. If you force the crank with a breaker bar and a socket without pulling the plugs, there is nowhere for the fluid to go and bad things happen to connecting rods.
    MyBBPYota and scottalot like this.
  5. Dec 3, 2017 at 8:14 AM
    #65
    TurdGenBrah
    TurdGenBrah [OP] Well-Known Member
    2016 Black TRD Off-Road ACLB Tacoma
    CB radio, ARB bumper, OME 886 coils w/ Nitrocharger shocks, TRD Pro grill
    I meant if I do turn the motor over with the starter and make things worse there's definitely not gonna be much they can do for me. Thanks.
  6. Dec 3, 2017 at 8:16 AM
    #66
    TurdGenBrah
    Pull plugs and manually turn the motor with a breaker bar then Or you're saying it's already locked up and I should just light a match...
  7. Dec 3, 2017 at 8:17 AM
    #67
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    sorry about the disconnecting the battery confusion. I just ment disconnect the battery while you pull the plugs so it will reset the computer. yeah you have to hook the battery back up to turn the motor over
    TurdGenBrah[OP] likes this.
  8. Dec 3, 2017 at 8:17 AM
    #68
    Iamraiderpower
    Iamraiderpower Well-Known Member
    get a couple of buddies to come by and prepare for some fun! Pull the plugs, chock the rear wheels, ebrake on, trans in neutral. Throw a socket with Breaker bar on it, and slowly start turning. You will meet some resistance, thats normal but if there is oil in the cylinders it will come right on out.
  9. Dec 3, 2017 at 8:26 AM
    #69
    Plain Jane Taco
    USA
    Once the plugs are all out....yes, use the starter to bump the engine. Obviously you'll need to have the battery hooked up to do this
    mynewtoy likes this.
  10. Dec 3, 2017 at 8:40 AM
    #70
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It could go either way. If you immediately got the infamous hydrolock "click" when trying to turn it over, that means fluid is in the cylinder and the starter is not strong enough to push passed it. Which could mean you are fine, or it could mean it already bent a rod.
    The starter and paper towel trick is to quickly eject the oil via the spark plug holes. If the starter won't turn over the engine even with the plugs removed, chances are at least one is bent already. Breaker bar and socket might free it up.
    Riding Dirty and scottalot like this.
  11. Dec 3, 2017 at 8:48 AM
    #71
    TurdGenBrah
  12. Dec 3, 2017 at 8:54 AM
    #72
    habanero_taco
    habanero_taco Well-Known Member
    Randy
    2016 Tacoma TRD Sport
    OVTuned
    One other thing to consider, and I actually had this happen... something got kicked up and lodged between the serpentine belt and a pulley. I had a bolt that came loose, fell off the engine and got lodged between the belt and the crank pulley, locked it up tighter than a drum.
  13. Dec 3, 2017 at 9:07 AM
    #73
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Yeah I don't get why OP took that line?
    t.hornstra likes this.
  14. Dec 3, 2017 at 9:11 AM
    #74
    icegrill
    icegrill Well-Known Member
    Oregon
    2015 Tacoma TRD (sold) bmw F80 M3 current
    This is why our insurance is expensive.:facepalm:
  15. Dec 3, 2017 at 9:17 AM
    #75
    J.M Taco
    J.M Taco Well-Known Member
    Central California
    '17 Tacoma Quicksand DCSB TRD OR 4x4
    :spy:
    Asking for a friend:
    Let’s say I flipped truck with a Diesel engine flipped. The engine will not turn by hand or by starter. How would one go about getting the oil out of the pistons?
    wilcam47 likes this.
  16. Dec 3, 2017 at 9:18 AM
    #76
    Taco16LB
    Taco16LB Well-Known Member
    Pull the glow plugs ?
    fdbyrne likes this.
  17. Dec 3, 2017 at 9:19 AM
    #77
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Because he did it on purpose? I'm sure you must have a perfect driving record with zero accidents and zero tickets.
    Riding Dirty, RogueTRD and scottalot like this.
  18. Dec 3, 2017 at 9:20 AM
    #78
    TurdGenBrah
    This isn't insurable anyway guys, it happened off a designated road on private property
    Heepspo and scottalot like this.
  19. Dec 3, 2017 at 9:21 AM
    #79
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Exactly. Some people are self entitled no matter what the situation is.
  20. Dec 3, 2017 at 9:21 AM
    #80
    TurdGenBrah
    Cause it's a sweet line, sheesh next you're gonna tell me what groceries to buy next time I'm at the mall.
    TacomaUSA, beriman10, BlakeM and 4 others like this.
